Trying to run sudo apt install node-acorn produces an error:
The following packages have unmet dependencies: node-acorn : Depends: nodejs:any or nodejs (< 12.22.5~dfsg-4~) but 18.14.2-deb-1nodesource1 is to be installed E: Unable to correct problems, you have held broken packages.
I am on Ubuntu 22.04. I have the current LTS version (18.14.2) of nodejs installed, but it seems there is some misconfiguration either on my part or on the side of node-acorn packagers. I also have acorn installed via npm, but I want to install emscripten, which has node-acorn as a dependency (the npm copy doesn't seem to matter to it). Do you have any suggestions on how to fix this issue?
Here is the output of apt show node-acorn -a:
Version: 8.7.0+ds+~cs24.17.6-1
Priority: optional
Section: universe/javascript
Source: acorn
Origin: Ubuntu
Maintainer: Ubuntu Developers <ubuntu-devel-discuss@lists.ubuntu.com>
Original-Maintainer: Debian Javascript Maintainers <pkg-javascript-devel@lists.alioth.debian.org>
Bugs: https://bugs.launchpad.net/ubuntu/+filebug
Installed-Size: 972 kB
Provides: node-acorn-bigint (= 1.0.0), node-acorn-class-fields (= 1.0.0), node-acorn-dynamic-import (= 4.0.0), node-acorn-export-ns-from (= 0.2.0), node-acorn-globals (= 6.0.0), node-acorn-import-assertions (= 1.8.0), node-acorn-import-meta (= 1.1.0), node-acorn-jsx (= 5.3.1), node-acorn-loose (= 8.2.1), node-acorn-node (= 2.0.1), node-acorn-numeric-separator (= 0.3.4), node-acorn-private-class-elements (= 1.0.0), node-acorn-private-methods (= 1.0.0), node-acorn-static-class-features (= 1.0.0), node-acorn-walk (= 8.2.0), node-debbundle-acorn (= 8.7.0+ds+~cs24.17.6-1)
Depends: node-xtend, nodejs:any | nodejs (<< 12.22.5~dfsg-4~)
Breaks: node-acorn-dynamic-import (<< 4.0.0~), node-acorn-jsx (<< 5.0.0~), node-acorn-object-spread (<< 6~), node-babel (<< 7), node-debbundle-acorn (<< 8.5.0+ds+~cs24.17.6~), node-espree (<< 6~), node-falafel (<< 2.1.0-9~), webpack (<< 4.28.3~)
Replaces: node-acorn-dynamic-import (<< 4.0.0+really4.0.0~), node-acorn-jsx (<< 5.0.0~), node-debbundle-acorn (<< 8.5.0+ds+~cs24.17.6~)
Homepage: https://github.com/ternjs/acorn/
Download-Size: 117 kB
APT-Sources: http://us.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
Description: ECMAScript parser for Node.js
 Acorn is a tiny, fast JavaScript parser written in JavaScript.
 acorn.js defines the main parser interface. The library also comes with a
 error-tolerant parser and an abstract syntax tree walker, defined in other
 files.
 This package contains the acorn module for Node.js.
 This package contains also small pluggins packages acorn-bigint,
 acorn-dynamic-import, acorn-jsx, acorn-node, acorn-private-class-elements,
 acorn-class-fields, acorn-static-class-features, acorn-export-ns-from,
 acorn-numeric-separator, acorn-private-methods.
 Node.js is an event-based server-side JavaScript engine.
I have worked around the issue by switching to Ubuntu 20.10, wiping out nodejs installation and reinstalling it from Canonical's repository rather than from Nodesource's (Had to use Nodesource with 22.04 because its "native" version was too old.)
