I have .ovpn file, exported from OpenVPN server:
dev tun
persist-tun
persist-key
cipher AES-256-CBC
auth SHA512
client
resolv-retry infinite
remote xxx.xxx.xxx.xxx 1194 udp
lport 0
verify-x509-name "C=xxx, ST=xxx, L=xxx, O=xxx, emailAddress=xxx@xxx.xxx, CN=xxx" subject
remote-cert-tls server
auth-user-pass auth.txt
comp-lzo adaptive
pkcs12 xxx.p12
tls-auth xxx-tls.key 1
Sure I have auth.txt, xxx.p12 and xxx-tls.key files, exported from the same OpenVPN server
Can anyone please explain me, what have I do to config client with this files on Ubuntu 22.04?
I've installed openvpn (apt-get install openvpn)
Put all the files to /etc/openvpn/client
Tried to openvpn --config /etc/openvpn/client/xxx.ovpn
Have an error Cannot pre-load keyfile (xxx-tls.key)
I'm not sure these steps are right...
This was helpful for me:
  1. Export one .ovpn file from server instead of several:
dev tun
persist-tun
persist-key
cipher AES-256-CBC
auth SHA512
client
lport 0
comp-lzo adaptive
<ca>
-----BEGIN CERTIFICATE-----
***DATA***
-----END CERTIFICATE-----
</ca>
<cert>
***DATA***
</cert>
<key>
-----BEGIN PRIVATE KEY-----
***DATA***
-----END PRIVATE KEY-----
</key>
<tls-auth>
# 2048 bit OpenVPN static key
-----BEGIN OpenVPN Static key V1-----
***DATA***
-----END OpenVPN Static key V1-----
</tls-auth>
key-direction 1
  1. Rename .ovpn file to client.conf
  2. Copy client.conf and auth.txt to /etc/openvpn
  3. Run systemctl start openvpn@client
