I've looked at How do I run a 'sudo' command inside a script? but this seems to be a different issue.
I want to run a script to change from root to the mastodon user using su, run Rails commands, and then exit back to the root account and restart mastodon.
Manually, I can log into root via ssh root@123.456.78.90 which gives me the root@Mastodon:~# shell. Then I use sudo su - mastodon to change to the mastodon account (I am not prompted for a password) and then cd live. Then I can run the Rails commands, etc., and they work, and then I can exit and run systemctl restart mastodon-*.
But my shell script to do the same thing doesn't work. The restartall script is
#!/bin/bash
sudo su - mastodon
cd live
RAILS_ENV=production bundle exec rake tmp:cache:clear
RAILS_ENV=production bundle exec rails assets:generate_static_pages
RAILS_ENV=production bundle exec rails assets:precompile
exit
and I run it this way root@Mastodon:~# ./restartall
The terminal user and path change to mastodon@MyMastodon, but that's all; the script fails wth: ./restartall: line 5: cd: live: No such file or directory
I also tried root@Mastodon:~# sudo ./restartall
What am I doing wrong in using su to change to the mastodon user?
Will simply using exit correctly take the script back to root@Mastodon before systemctl restart mastodon-* ?
The reason this fails is that sudo su - mastodon starts a new interactive shell as user mastodon. Any commands that follow are not executed until that shell exits.
You could pass the commands to su via its -c option, as described in the previous question after su, the script stops working, so
#!/bin/bash
sudo su -l mastodon -c ' cd live RAILS_ENV=production bundle exec rake tmp:cache:clear RAILS_ENV=production bundle exec rails assets:generate_static_pages RAILS_ENV=production bundle exec rails assets:precompile '
(you don't need an explicit exit at the end of the commands passed via -c since the non-interactive su shell will exit naturally when it runs out of commands to execute).
Alternatively, you could use a here-document to pass the commands to the su shell via standard input, as described in how to write a script that will run commands after su, without using -c but please note the warning about commands that themselves read from stdin.
However you could consider avoiding su altogether, and writing your script so that it checks who is running it, and re-executes itself as the target user if required, like
#!/bin/bash
rails_user=mastodon
if [[ $EUID -ne $(id -u $rails_user) ]]; then echo "Switching to user '$rails_user' to perform tasks" exec sudo -iu "$rails_user" "$(realpath $0)" fi
cd live
etc.
steeldriver
  • 142,475
