I have followed a number of tutorials to install NVIDIA drivers on Ubuntu 22.04, but none has worked so far. Before the update, on Ubuntu 20.04, everything worked fine.
I have tried to install the driver via GUI and console as well. In the console, I have tried to install versions nvidia-driver-525, nvidia-driver-470, and nvidia-driver-515-open by running
sudo apt install [driver version]
I have RTX2080Ti.
If I run sudo ubuntu-drivers autoinstall, I get the following error:
dpkg: warning: version 'unsigned-5.18.10-051810' has bad syntax: version number does not start with digit
Traceback (most recent call last):
File "/usr/bin/ubuntu-drivers", line 513, in <module>
greet()
File "/usr/lib/python3/dist-packages/click/core.py", line 1128, in __call__
return self.main(*args, **kwargs)
File "/usr/lib/python3/dist-packages/click/core.py", line 1053, in main
rv = self.invoke(ctx)
File "/usr/lib/python3/dist-packages/click/core.py", line 1659, in invoke
return _process_result(sub_ctx.command.invoke(sub_ctx))
File "/usr/lib/python3/dist-packages/click/core.py", line 1395, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "/usr/lib/python3/dist-packages/click/core.py", line 754, in invoke
return __callback(*args, **kwargs)
File "/usr/lib/python3/dist-packages/click/decorators.py", line 84, in new_func
return ctx.invoke(f, obj, *args, **kwargs)
File "/usr/bin/ubuntu-drivers", line 432, in autoinstall
command_install(config)
File "/usr/bin/ubuntu-drivers", line 187, in command_install
UbuntuDrivers.detect.nvidia_desktop_pre_installation_hook(to_install)
File "/usr/lib/python3/dist-packages/UbuntuDrivers/detect.py", line 839, in nvidia_desktop_pre_installation_hook
with_nvidia_kms = version >= 470
UnboundLocalError: local variable 'version' referenced before assignment
Any help is highly appreciated.
