Initially I installed node using the command sudo apt install nodejs. This command installed an older version of node and npm so I removed the package using the command
sudo apt-get remove --purge nodejs.
To get the latest LTS version of nodejs I download the zip file extracted it to the path /usr/local/lib/nodejs/.
After this to set the environment variable of nodejs I took the path of nodejs bin file, then configured the path to .bashrc file which was present in the home directory.
This is how I installed the latest LTS version of nodejs and npm. I also verified the installation by checking the versions of node and npm in my system.
Now when I run npm install -g nodemon it gives me error stating that you need specific permissions to do so.
Then I tried sudo npm install -g nodemon, now it says command not found.
But I can install nodemon locally (i.e npm install nodemon works fine but still can't start the node server using nodemon). What I want is to install nodemon globally and use it to start my server
I googled around and tried several things but it didn't really work for me.
Newbie here... It's been two weeks where I have totally wiped windows from my system and installed ubuntu in it.
Rishon_JR
  • 1,028
Firstly, you can install npm on Ubuntu 22.04 LTS by opening terminal and run the following commands:
$ sudo apt update
$ sudo apt install npm
After that, you can install nodemon globally on our system with the following command:
$ sudo npm install -g nodemon
I tested and installed nodemon successfully on my Ubuntu 22.04.2 LTS server. Hope this help you fix your problem.
