I'm trying to install Ubuntu on an old Shuttle, using a USB stick. On booting, I get a screen with GNU GRUB 2.06 and a menu of 4 choices:
Try or Install Ubuntu
Ubuntu (safe graphics)
OEM install (for manufacturers)
Test memory
Apart from test memory (which does report some errors, but I think a memory hole fixes that; anyway the BIOS also tests memory and reports no errors) any of the first 3 options simply brings up a dark screen with a cursor flashing top left. I have left it for several minutes but nothing more has happened.
Here's the background. I have downloaded both ubuntu-22.04.1-desktop-amd64.iso ubuntu-22.10-desktop-amd64.iso on my iMac and used BalenaEtcher to flash them to USB sticks. I have tried 2 different sticks and two different USB ports in case they were at fault. The Shuttle specs are:
Processor: 3GHz Pentium(R) CPU with Hyper-Threading Technology
Memory: 1GB
Disk: Maxtor 6Y120L0, 120GB
Optical: Optiarc DVD RW AD-5200A 1.05
Not ideal, but surely adequate. The Shuttle currently runs Windows XP from the hard disk.
I could perhaps boot Ubuntu off the DVD drive instead, but I thought the USB route was simpler and more likely to succeed.
Any suggestions? Thanks ...
As you can see at the official web site
Minimum requirements for Ubuntu 22.04 are:
4 GB system memory
1 GB is obviously not enough.
Pilot6
  • 92,041
