I found that whenever I leave my laptop idle for a while (no suspend because of Caffeine)it gets stuck and I need to force reboot the system by the power button. I tried disabling all the startup applications, disabling and even uninstalling the extensions which appear on syslog, etc.
I enabled a system monitor extension and I found whenever I leave the system idle, RAM usage is getting higher until everything gets stuck. So, before I lose control of everything I used system monitor and found that Gnome-shell is using 2.3GB RAM!
I restarted the shell (Alt-F2 then r) and the RAM usage reduced down to 237MB. using tail -f /var/log/syslog gives me errors like this:
gnome-shell[4646]: #0 5572a9982f20 i resource:///org/gnome/shell/ui/dateMenu.js
and using pmap `pgrep gnome-shell` | grep -v -i deleted > /tmp/gnome-pmap1.dump will give me errors like this related to the calendar:
2057: /usr/libexec/gnome-shell-calendar-server
Using memstat (mentioned here I found that the problem is mostly made by chrome_crashpad_handler and when I kill this process everything is fine, but I don't know how to disable or totally remove it, and I don't know what it is at all!
Before-after picture is attached.
My system specs are:
  • Ubuntu 22.10,
  • Gnome 43.1,
  • X11,
  • On a Dell Thinkpad Inspiron 7348 with
    • 4GB RAM,
    • Core i5 CPU
    • Intel Graphics
before restarting shell
after
zx485
  • 2,865
After disabling everything suspicious, I still had the issue but before getting ram usage too much that I can't check anything, I used tail -f /var/log/syslog and faced too many errors like this:
Feb 26 20:46:46 thinkpad-lap gnome-shell[2087]: #0   55c0fea1a048 i   resource:///org/gnome/shell/ui/dateMenu.js:370 (34058da3b830 @ 55)
Feb 26 20:46:45 thinkpad-lap gnome-shell[2087]: Object .Gjs_ui_dateMenu_EventsSection (0x55c0f7150cd0), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
Feb 26 20:46:46 thinkpad-lap gnome-shell[2087]: == Stack trace for context 0x55c0f38d1190 ==
there was a lot of errors and things like these, so I started to search one by one, and found this bug and solution
after backing up my clock setting:
dbus-launch dconf dump / > gnome-desktop.dconf
I did reset all clocks settings with:
dbus-launch dconf reset -f /org/gnome/clocks/
dbus-launch dconf reset -f /org/gnome/shell/world-clocks/
and it relieved me of an old disgusting problem.
