I've installed Lubuntu 22.04.1 on a Mac mini (2014). The WiFi isn't working and I'm guessing it's a driver issue, but I'm not sure. I would really appreciate it if someone could explain what the problem is. The following is the output from the wireless-info script:
########## wireless info START ##########
Report from: 20 Feb 2023 20:03 PST -0800
Booted last: 20 Feb 2023 00:00 PST -0800
Script from: 25 Jan 2020 03:34 UTC +0000
release
Distributor ID: Ubuntu Description: Ubuntu 22.04.1 LTS Release: 22.04 Codename: jammy
kernel
Linux 5.15.0-43-generic #46-Ubuntu SMP Tue Jul 12 10:30:17 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
Parameters: ro, quiet, splash, vt.handoff=7
desktop
Lubuntu
lspci
02:00.0 Network controller [0280]: Broadcom Inc. and subsidiaries BCM4360 802.11ac Wireless Network Adapter [14e4:43a0] (rev 03) Subsystem: Apple Inc. BCM4360 802.11ac Wireless Network Adapter [106b:013b] Kernel driver in use: bcma-pci-bridge
03:00.0 Ethernet controller [0200]: Broadcom Inc. and subsidiaries NetXtreme BCM57766 Gigabit Ethernet PCIe [14e4:1686] (rev 01) Subsystem: Broadcom Inc. and subsidiaries NetXtreme BCM57766 Gigabit Ethernet PCIe [14e4:1686] Kernel driver in use: tg3
lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 001 Device 007: ID 04ca:0061 Lite-On Technology Corp. USB Optical Mouse Bus 001 Device 005: ID 0461:3f41 Primax Electronics, Ltd HP Wired Desktop 320K Keyboard Bus 001 Device 003: ID 05ac:8242 Apple, Inc. Built-in IR Receiver Bus 001 Device 008: ID 05ac:8289 Apple, Inc. Bluetooth Host Controller Bus 001 Device 002: ID 0a5c:4500 Broadcom Corp. BCM2046B1 USB 2.0 Hub (part of BCM2046 Bluetooth) Bus 001 Device 009: ID 154b:007a PNY Classic Attache Flash Drive Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
PCMCIA card info
rfkill
0: hci0: Bluetooth Soft blocked: no Hard blocked: no
secure boot
This system doesn't support Secure Boot
lsmod
b43 495616 0 cordic 16384 1 b43 mac80211 1228800 1 b43 cfg80211 958464 2 b43,mac80211 libarc4 16384 1 mac80211 ssb 86016 1 b43 bcma 69632 1 b43
interfaces
ifconfig
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback <MAC address> brd <MAC address> inet 127.0.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host valid_lft forever preferred_lft forever 2: enp3s0f0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000 link/ether <MAC 'enp3s0f0' [IF1]> brd <MAC address>
iwconfig
lo no wireless extensions.
enp3s0f0 no wireless extensions.
route
resolv.conf
[777 root '/etc/resolv.conf' -> '../run/systemd/resolve/stub-resolv.conf']
nameserver 127.0.0.53 options edns0 trust-ad search .
network managers
Installed:
NetworkManager
Running:
root 841 1 0 18:53 ? 00:00:01 /usr/sbin/NetworkManager --no-daemon
NetworkManager info
GENERAL.DEVICE: enp3s0f0 GENERAL.TYPE: ethernet GENERAL.NM-TYPE: NMDeviceEthernet GENERAL.DBUS-PATH: /org/freedesktop/NetworkManager/Devices/2 GENERAL.VENDOR: Broadcom Inc. and subsidiaries GENERAL.PRODUCT: NetXtreme BCM57766 Gigabit Ethernet PCIe GENERAL.DRIVER: tg3 GENERAL.DRIVER-VERSION: 5.15.0-43-generic GENERAL.FIRMWARE-VERSION: 57766a-v1.15 GENERAL.HWADDR: <MAC 'enp3s0f0' [IF1]> GENERAL.MTU: 1500 GENERAL.STATE: 20 (unavailable) GENERAL.REASON: 2 (Device is now managed) GENERAL.IP4-CONNECTIVITY: 1 (none) GENERAL.IP6-CONNECTIVITY: 1 (none) GENERAL.UDI: /sys/devices/pci0000:00/0000:00:1c.3/0000:03:00.0/net/enp3s0f0 GENERAL.PATH: pci-0000:03:00.0 GENERAL.IP-IFACE: -- GENERAL.IS-SOFTWARE: no GENERAL.NM-MANAGED: yes GENERAL.AUTOCONNECT: yes GENERAL.FIRMWARE-MISSING: no GENERAL.NM-PLUGIN-MISSING: no GENERAL.PHYS-PORT-ID: -- GENERAL.CONNECTION: -- GENERAL.CON-UUID: -- GENERAL.CON-PATH: -- GENERAL.METERED: unknown CAPABILITIES.CARRIER-DETECT: yes CAPABILITIES.SPEED: unknown CAPABILITIES.IS-SOFTWARE: no CAPABILITIES.SRIOV: no INTERFACE-FLAGS.UP: yes INTERFACE-FLAGS.LOWER-UP: no INTERFACE-FLAGS.CARRIER: no INTERFACE-FLAGS.PROMISC: no WIRED-PROPERTIES.CARRIER: off IP4.GATEWAY: -- IP6.GATEWAY: -- CONNECTIONS.AVAILABLE-CONNECTION-PATHS: --
NetworkManager.state
cat: /var/lib/NetworkManager/NetworkManager.state: No such file or directory
NetworkManager config
[[/etc/NetworkManager/conf.d/default-wifi-powersave-on.conf]] [connection] wifi.powersave = 3
[[/etc/NetworkManager/NetworkManager.conf]] [main] plugins=ifupdown,keyfile [ifupdown] managed=false [device] wifi.scan-rand-mac-address=no
[[/usr/lib/NetworkManager/conf.d/10-dns-resolved.conf]] [main] dns=systemd-resolved
[[/usr/lib/NetworkManager/conf.d/10-globally-managed-devices.conf]] [keyfile] unmanaged-devices=*,except:type:wifi,except:type:gsm,except:type:cdma
[[/usr/lib/NetworkManager/conf.d/no-mac-addr-change.conf]] [device-31-mac-addr-change] match-device=driver:eagle_sdio,driver:wl wifi.scan-rand-mac-address=no
NetworkManager profiles
Netplan config
[/etc/netplan/01-network-manager-all.yaml] network: version: 2 renderer: NetworkManager
iw reg get
'iw' is not installed (package "iw").
iwlist channels
lo no frequency information.
enp3s0f0 no frequency information.
iwlist scan
lo Interface doesn't support scanning.
enp3s0f0 Interface doesn't support scanning.
module infos
[b43] filename: /lib/modules/5.15.0-43-generic/kernel/drivers/net/wireless/broadcom/b43/b43.ko license: GPL description: Broadcom B43 wireless driver depends: mac80211,ssb,bcma,cfg80211,cordic retpoline: Y intree: Y name: b43 vermagic: 5.15.0-43-generic SMP mod_unload modversions parm: bad_frames_preempt:enable(1) / disable(0) Bad Frames Preemption (int) parm: fwpostfix:Postfix for the .fw files to load. (string) parm: hwpctl:Enable hardware-side power control (default off) (int) parm: nohwcrypt:Disable hardware encryption. (int) parm: hwtkip:Enable hardware tkip. (int) parm: qos:Enable QOS support (default on) (int) parm: btcoex:Enable Bluetooth coexistence (default on) (int) parm: verbose:Log message verbosity: 0=error, 1=warn, 2=info(default), 3=debug (int) parm: pio:Use PIO accesses by default: 0=DMA, 1=PIO (int) parm: allhwsupport:Enable support for all hardware (even it if overlaps with the brcmsmac driver) (int)
[mac80211] filename: /lib/modules/5.15.0-43-generic/kernel/net/mac80211/mac80211.ko license: GPL description: IEEE 802.11 subsystem depends: cfg80211,libarc4 retpoline: Y intree: Y name: mac80211 vermagic: 5.15.0-43-generic SMP mod_unload modversions parm: minstrel_vht_only:Use only VHT rates when VHT is supported by sta. (bool) parm: max_nullfunc_tries:Maximum nullfunc tx tries before disconnecting (reason 4). (int) parm: max_probe_tries:Maximum probe tries before disconnecting (reason 4). (int) parm: beacon_loss_count:Number of beacon intervals before we decide beacon was lost. (int) parm: probe_wait_ms:Maximum time(ms) to wait for probe response before disconnecting (reason 4). (int) parm: ieee80211_default_rc_algo:Default rate control algorithm for mac80211 to use (charp)
[cfg80211] filename: /lib/modules/5.15.0-43-generic/kernel/net/wireless/cfg80211.ko description: wireless configuration support license: GPL depends:
retpoline: Y intree: Y name: cfg80211 vermagic: 5.15.0-43-generic SMP mod_unload modversions parm: bss_entries_limit:limit to number of scan BSS entries (per wiphy, default 1000) (int) parm: ieee80211_regdom:IEEE 802.11 regulatory domain code (charp) parm: cfg80211_disable_40mhz_24ghz:Disable 40MHz support in the 2.4GHz band (bool)
[ssb] filename: /lib/modules/5.15.0-43-generic/kernel/drivers/ssb/ssb.ko license: GPL description: Sonics Silicon Backplane driver depends:
retpoline: Y intree: Y name: ssb vermagic: 5.15.0-43-generic SMP mod_unload modversions
[bcma] filename: /lib/modules/5.15.0-43-generic/kernel/drivers/bcma/bcma.ko license: GPL description: Broadcom's specific AMBA driver depends:
retpoline: Y intree: Y name: bcma vermagic: 5.15.0-43-generic SMP mod_unload modversions
module parameters
[b43] allhwsupport: 0 bad_frames_preempt: 0 btcoex: 1 hwpctl: 0 hwtkip: 0 nohwcrypt: 0 pio: 0 qos: 1 verbose: 2
[mac80211] beacon_loss_count: 7 ieee80211_default_rc_algo: minstrel_ht max_nullfunc_tries: 2 max_probe_tries: 5 minstrel_vht_only: Y probe_wait_ms: 500
[cfg80211] bss_entries_limit: 1000 cfg80211_disable_40mhz_24ghz: N ieee80211_regdom: 00
/etc/modules
modprobe options
[/etc/modprobe.d/amd64-microcode-blacklist.conf] blacklist microcode
[/etc/modprobe.d/blacklist-ath_pci.conf] blacklist ath_pci
[/etc/modprobe.d/blacklist.conf] blacklist evbug blacklist usbmouse blacklist usbkbd blacklist eepro100 blacklist de4x5 blacklist eth1394 blacklist snd_intel8x0m blacklist snd_aw2 blacklist prism54 blacklist bcm43xx blacklist garmin_gps blacklist asus_acpi blacklist snd_pcsp blacklist pcspkr blacklist amd76x_edac
[/etc/modprobe.d/blacklist-rare-network.conf] alias net-pf-3 off alias net-pf-6 off alias net-pf-9 off alias net-pf-11 off alias net-pf-12 off alias net-pf-19 off alias net-pf-21 off alias net-pf-36 off
[/etc/modprobe.d/intel-microcode-blacklist.conf] blacklist microcode
[/etc/modprobe.d/iwlwifi.conf] remove iwlwifi
(/sbin/lsmod | grep -o -e ^iwlmvm -e ^iwldvm -e ^iwlwifi | xargs /sbin/rmmod)
&& /sbin/modprobe -r mac80211
rc.local
grep: /etc/rc.local: No such file or directory
pm-utils
udev rules
dmesg
[ 16.658347] b43-phy0: Broadcom 4360 WLAN found (core revision 42) [ 16.658764] b43-phy0 ERROR: FOUND UNSUPPORTED PHY (Analog 12, Type 11 (AC), Revision 1) [ 16.658773] b43: probe of bcma0:1 failed with error -95
########## wireless info END ############
Ian
