I have Ubuntu 22.04 installed on a windows 10 machine using VirtualBox. Occassionally it will freeze (once while using it but mostly I find it frozen after walking away from the PC when I return.
Has anyone suggestions on where to look for logs or how to troubleshoot (or even better solve) this issue?
Update 1 error found after running journalctl:
kernel: [Firmware Bug]: TSC doesn't count with P0 frequency!
kernel: APIC calibration not consistent with PM-Timer: 108ms instead of 100ms
kernel: .... node #0, CPUs: #1
kernel: TSC synchronization [CPU#0 -> CPU#1]:
kernel: Measured 19079 cycles TSC warp between CPUs, turning off TSC clock.
kernel: tsc: Marking TSC unstable due to check_tsc_sync_source failed
kernel: #2 #3 #4 #5
kernel: smp: Brought up 1 node, 6 CPUs
