I have an rtl8852be WiFi card. After some initial trouble with the software not working with the card I came across this thread: wifi Adapter not found realtek RTL8852BE WiFi 6 802.11ax PCIe in ubuntu 22.04
This has worked for the last few months but after the last kernel update I now get the following message after recompiling:
elli@elli-ThinkPad-E15-Gen-4:~/rtl8852be$ make
#rm -f .symvers.8852be
make ARCH=x86_64 CROSS_COMPILE= -C /lib/modules/5.19.0-32-generic/build M=/home/elli/rtl8852be  modules
make[1]: Verzeichnis „/usr/src/linux-headers-5.19.0-32-generic“ wird betreten
warning: the compiler differs from the one used to build the kernel
  The kernel was built by: x86_64-linux-gnu-gcc (Ubuntu 11.3.0-1ubuntu1~22.04) 11.3.0
  You are using:           gcc (Ubuntu 11.3.0-1ubuntu1~22.04) 11.3.0
  CC [M]  /home/elli/rtl8852be/platform/platform_linux_pc_pci.o
/home/elli/rtl8852be/platform/platform_linux_pc_pci.c: In function ‘pci_cache_wback’:
/home/elli/rtl8852be/platform/platform_linux_pc_pci.c:21:17: error: implicit declaration of function ‘pci_dma_sync_single_for_device’; did you mean ‘dma_sync_single_for_device’? [-Werror=implicit-function-declaration]
   21 |                 pci_dma_sync_single_for_device(hwdev, *bus_addr, size,
/home/elli/rtl8852be/platform/platform_linux_pc_pci.c: In function ‘pci_cache_inv’:
/home/elli/rtl8852be/platform/platform_linux_pc_pci.c:30:17: error: implicit declaration of function ‘pci_dma_sync_single_for_cpu’; did you mean ‘dma_sync_single_for_cpu’? [-Werror=implicit-function-declaration]
   30 |                 pci_dma_sync_single_for_cpu(hwdev, *bus_addr, size, direction);
/home/elli/rtl8852be/platform/platform_linux_pc_pci.c: In function ‘pci_get_bus_addr’:
/home/elli/rtl8852be/platform/platform_linux_pc_pci.c:39:29: error: implicit declaration of function ‘pci_map_single’; did you mean ‘dma_map_single’? [-Werror=implicit-function-declaration]
   39 |                 *bus_addr = pci_map_single(hwdev, vir_addr, size, direction);
      |                             dma_map_single
/home/elli/rtl8852be/platform/platform_linux_pc_pci.c: In function ‘pci_unmap_bus_addr’:
/home/elli/rtl8852be/platform/platform_linux_pc_pci.c:50:17: error: implicit declaration of function ‘pci_unmap_single’; did you mean ‘dma_unmap_single’? [-Werror=implicit-function-declaration]
   50 |                 pci_unmap_single(hwdev, *bus_addr, size, direction);
      |                 dma_unmap_single
/home/elli/rtl8852be/platform/platform_linux_pc_pci.c: In function ‘pci_free_noncache_mem’:
/home/elli/rtl8852be/platform/platform_linux_pc_pci.c:97:17: error: implicit declaration of function ‘pci_free_consistent’ [-Werror=implicit-function-declaration]
   97 |                 pci_free_consistent(pdev, size, vir_addr, *bus_addr);
cc1: some warnings being treated as errors
make[2]: *** [scripts/Makefile.build:257: /home/elli/rtl8852be/platform/platform_linux_pc_pci.o] Fehler 1
make[1]: *** [Makefile:1850: /home/elli/rtl8852be] Fehler 2
make[1]: Verzeichnis „/usr/src/linux-headers-5.19.0-32-generic“ wird verlassen
make: *** [Makefile:637: modules] Fehler 2
Sorry for the bits in German. Thanks in advance.
Pilot6
  • 92,041
Elli
  • 13
Your driver didn't build for the 5.19 kernel.
Install another one by
git clone https://github.com/HRex39/rtl8852be.git -b dev
cd rtl8852be
make
sudo make install
sudo modprobe 8852be
But you'll have to re-compile it after each kernel upgrade unless you create a DKMS module.
Pilot6
  • 92,041
