I create an ISO with autoinstall that needs to be generic. It should work on VMs, physical machines with legacy bios, EFI bios, with and without RAID.
In my autoinstall.yml, I don't have anything related to storage (as I want it to be as generic as possible for all the platforms):
#cloud-config
autoinstall:
  version: 1
  identity:
    hostname: fooapp
    username: foouser
    password: "XXXXXXX"
  network:
    ethernets: {}
    version: 2
  source:
  early-commands:
  - cat /cdrom/casper/install-sources.yaml | awk 'NR>1 && /^-/{exit};1' > /run/my-sources.yaml
  - mount -o ro,bind /run/my-sources.yaml /cdrom/casper/install-sources.yaml
  late-commands:
    - cp -r /cdrom/copy_to_iso/ /target/opt/
user-data:
    runcmd:
        echo -e "\033[32mDuring installation, please don't touch until the installation will be finished....\033[0m"
        mkdir -vp /opt/INIT/ >> /root/application_installation.log 2>&1
        mv -v /opt/copy_to_iso/upgrade_or_install_packages/ /opt/ >> /root/application_installation.log 2>&1
        mv -v /opt/copy_to_iso/foo_installation/* /opt/INIT/  >> /root/application_installation.log 2>&1
        mv -v /opt/copy_to_iso/application_scripts /opt/application_scripts >> /root/application_installation.log 2>&1
        rm -rvf /opt/copy_to_iso >> /root/application_installation.log 2>&1
        bash -x /opt/application_scripts/copy_system_files.sh >> /root/application_installation.log 2>&1
        bash -x /opt/application_scripts/setup_system_config.sh install_mode >> /root/application_installation.log 2>&1
        echo -e "\033[32mInstallation was completed...\033[0m"
The installation of the ISO is done successfully in all the platforms, except EFI bios with RAID1 (UEFI Option ROM Control > Virtual RAID on CPU). Note - without RAID, same platform, it works.
During the ISO installation, it fails on the stage of cmd-install/stage-partitioning/builtin/cmd-block-meta/clear-holders on the following error:
        mdadm: stop failed, retrying in 0.2 seconds
        mdadm: stop on /dev/md127 attempt 58
        /sys/class/block/md127/md/sync_action/sync_max =
        mdadm: setting array sync_action=idle
        mdadm: (non-fatal) write to /sys/class/block/md127/md/sync_action failed [Errno 13] Permission denied: '/sys/class/block/md127/md/sync_action'
        /sys/class/block/md127/md/sync_max/sync_max =
        mdadm: setting array sync_{min,max}=0
        mdadm: (non-fatal) write to /sys/class/block/md127/md/sync_max failed [Errno 13] Permission denied: '/sys/class/block/md127/md/sync_max'
        Running command ['mdadm', '--manage', '--stop', '/dev/md127'] with allowed return codes [0] (capture=True)
        mdadm stop failed, retrying
        /proc/mdstat:
        Personalities : [raid1] [linear] [multipath] [raid0] [raid6] [raid5] [raid4] [raid10]
        md126 : active raid1 nvme0n1[1] nvme1n1[0]
              3711654912 blocks super external:/md127/0 [2/2] [UU]
              [>....................]  resync =  0.0% (3059008/3711654912) finish=286.7min speed=215522K/sec
    md127 : inactive nvme1n1[1](S) nvme0n1[0](S)
          10402 blocks super external:imsm
    unused devices: <none>
    mdadm: stop on /dev/md127 attempt 59
    /proc/mdstat:
    finish: cmd-install/stage-partitioning/builtin/cmd-block-meta/clear-holders: FAIL: removing previous storage devices
    TIMED BLOCK_META: 15.083
    finish: cmd-install/stage-partitioning/builtin/cmd-block-meta: FAIL: curtin command block-meta
    Traceback (most recent call last):
      File "/snap/subiquity/3698/lib/python3.8/site-packages/curtin/commands/main.py", line 202, in main
        ret = args.func(args)
      File "/snap/subiquity/3698/lib/python3.8/site-packages/curtin/log.py", line 97, in wrapper
        return log_time("TIMED %s: " % msg, func, *args, **kwargs)
      File "/snap/subiquity/3698/lib/python3.8/site-packages/curtin/log.py", line 79, in log_time
        return func(*args, **kwargs)
      File "/snap/subiquity/3698/lib/python3.8/site-packages/curtin/commands/block_meta.py", line 108, in block_meta
        meta_clear(devices, state.get('report_stack_prefix', ''))
      File "/snap/subiquity/3698/lib/python3.8/site-packages/curtin/commands/block_meta.py", line 1984, in meta_clear
        clear_holders.clear_holders(devices)
      File "/snap/subiquity/3698/lib/python3.8/site-packages/curtin/block/clear_holders.py", line 638, in clear_holders
        shutdown_function(dev_info['device'])
      File "/snap/subiquity/3698/lib/python3.8/site-packages/curtin/block/clear_holders.py", line 205, in shutdown_mdadm
        mdadm.mdadm_stop(blockdev)
      File "/snap/subiquity/3698/lib/python3.8/site-packages/curtin/block/mdadm.py", line 353, in mdadm_stop
        raise OSError('Failed to stop mdadm device %s', devpath)
    OSError: [Errno Failed to stop mdadm device %s] /dev/md127
Do you have a suggestion? I tried to add to early-commands: the following -
- mdadm --manage --stop /dev/md126
- mdadm --manage --stop /dev/md127
It didn't help; same error.
Utz
  • 139
  • 15
