Ubuntu 22.04.1 LTS (GNU/Linux 6.0.12-00858-gb98721ea4575 aarch64)
after trying upgrade I get this
$ sudo apt upgrade
Reading package lists... Done Building dependency tree... Done Reading state information... Done Calculating upgrade... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation:
grub-efi-arm64-signed : Depends: grub-efi-arm64 (= 2.06-2ubuntu10) but 2.06-2ubuntu14 is to be installed E: Broken packages
I tried various suggestions from other posts but success
any ideas
Yes I did run apt update
$ sudo apt update
Hit:1 https://deb.libre.computer/repo linux InRelease
Hit:2 http://ports.ubuntu.com/ubuntu-ports jammy InRelease
Get:3 http://ports.ubuntu.com/ubuntu-ports jammy-updates InRelease [119 kB]
Get:4 http://ports.ubuntu.com/ubuntu-ports jammy-backports InRelease [107 kB]
Get:5 http://ports.ubuntu.com/ubuntu-ports jammy-security InRelease [110 kB]
Fetched 336 kB in 3s (96.9 kB/s)
98 packages can be upgraded. Run 'apt list --upgradable' to see them.
$ sudo apt upgrade Reading package lists... Done Building dependency tree... Done Reading state information... Done Calculating upgrade... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation:
The following packages have unmet dependencies: grub-efi-arm64-signed : Depends: grub-efi-arm64 (= 2.06-2ubuntu10) but 2.06-2ubuntu14 is to be installed
E: Broken packages
Output of sudo dpkg -l | grep '^.[^i]' :
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad) ||/ Name Version Architecture Description +++-========================================-=======================================-============-================================================================================
rusty
  • 16,917
Jon
