sudo apt upgrade and sudo apt full-upgrade doesn't work,the following 8 packages won't upgrade:
gnome-initial-setup/jammy-updates 42.0.1-1ubuntu2.2 amd64 [upgradable from: 42.0.1-1ubuntu2]
gnome-remote-desktop/jammy-updates 42.7-0ubuntu1 amd64 [upgradable from: 42.3-0ubuntu1]
python3-software-properties/jammy-updates,jammy-updates 0.99.22.5 all [upgradable from: 0.99.22.2]
software-properties-common/jammy-updates,jammy-updates 0.99.22.5 all [upgradable from: 0.99.22.2]
software-properties-gtk/jammy-updates,jammy-updates 0.99.22.5 all [upgradable from: 0.99.22.2]
ubuntu-advantage-tools/jammy-updates 27.13.3~22.04.1 amd64 [upgradable from: 27.9~22.04.1]
update-notifier-common/jammy-updates,jammy-updates 3.192.54.5 all [upgradable from: 3.192.54]
update-notifier/jammy-updates 3.192.54.5 amd64 [upgradable from: 3.192.54]
David DE
  • 2,316
This suggests that their is a reason these updates have been held back, either due to your apt settings, or they could conflict with another package. To fix it, just run apt install <package name>
if you want to install all of them in one command run:
apt full-upgrade | awk -F / ' {system("apt install "$1)}'
if you are not in a root shell, you will need to add sudo to both commands
sudo apt full-upgrade | awk -F / ' {system("sudo apt install "$1)}'
*** sudo or running apt in a root shell is assumed
Luke Attard
  • 1,065
