I try to run the following, but I get an error:
    sudo apt install r-base-core
    Reading package lists... Done
    Building dependency tree
    Some packages could not be installed. This may mean that you
    have
    requested an impossible situation or if you are using the
    unstable
    distribution that some required packages have not yet been
    created
r-base-core : Depends: libtcl8.6 (>= 8.6.0) but it is not
installable
       Depends: libtk8.6 (>= 8.6.0) but it is not installable
       Recommends: r-recommended but it is not going to be
installed
      Recommends: r-base-dev but it is not going to be
installed
       Recommends: r-doc-html but it is not going to be
installed
How can I avoid this error?
Starship
  • 151
dju_V
