I am running VirtualBox on a Windows Machine, and installed Ubuntu Linux 22.04 LTS. During the install, I set up the initial user. However, there appears to be no way to make this user have admin (sudo) privileges. After the install, I can login as the user, but I can't do anything involving admin (meaning, I can't use sudo). If there is a root password, I don't know what it is. (I think by default there is no password for root.)
I tried doing the trick where you run in recovery mode to run as root...but even then it prompts me for a root password, so I can't do anything.
I did the entire install process a second time, thinking I missed something, but to no avail.
Any advice on how to determine what the root password is when you install using VirtualBox? Or how to create a user that ends up in sudoers?
