I am trying to install docker-desktop on Ubuntu 22.04.1 LTS. However, when I try to run the following command, it shows errors.
sudo apt install ./docker-desktop-*-amd64.deb
The output of this command is:
Reading package lists...
Done Building dependency tree...
Done Reading state information...
Done
Note, selecting 'docker-desktop' instead of './docker-desktop-4.12.0-amd64.deb'
Some packages could not be installed. This may mean that you have requested an
impossible situation or if you are using the unstable distribution that some
required packages have not yet been created or been moved out of Incoming.
docker-desktop : Depends: pass but it is not installable
Depends: uidmap but it is not installable
Done
I have already installed docker:
$ docker -v
Docker version 23.0.0, build e92dd87
