I am running Ubuntu MATE 22.04 on a Chromebook. Due to the limited internal memory of a Chromebook, I am using a 128 GB USB drive for storage. This drive is formatted as exfat, so that it can be used in both Windows and GNU/Linux. I want to automount the disk, so that its permanent location would not change, and my Cloud Storage Client (Mega) would be able to access it witout manual intervention.
I opened Mount options for this Drive in GNOME Disks, and enabled Mount at Startup.
After doing this, I cannot edit files in the drive. The drive is mounted as /mnt/MyDrive.
I tried sudo chown -R myusername:myusername /mnt/MyDrive, but it did not work (despite using sudo, it says "Operation not permitted").
I tried logging as root with su and chown -R myusername:myusername /mnt/Files, but still it says "Operation not permitted").
How do I fix this? I want to automount the drive, but also want to have read-write access.
Note: If I don't automount the drive, I have full read-write access in it (without sudo). In the past, I have automounted ext4 drives, and I could chown it with sudo without an issue. This issue is specific to exfat (and maybe NTFS as well).
