I have recently installed ubuntu server and I have tried to run updates. Here is the output:
:~$ sudo apt update
Hit:1 http://us.archive.ubuntu.com/ubuntu jammy InRelease
Hit:2 http://us.archive.ubuntu.com/ubuntu jammy-updates InRelease
Hit:3 http://us.archive.ubuntu.com/ubuntu jammy-backports InRelease
Hit:4 http://us.archive.ubuntu.com/ubuntu jammy-security InRelease
Reading package lists... Done
Building dependency tree... Done
76 packages can be upgraded. Run 'apt list --upgradable' to see them.
and
:~$ sudo apt update && sudo apt upgrade
[sudo] password for admina:
Get:2 http://us.archive.ubuntu.com/ubuntu jammy-updates InRelease [114 kB]
Get:3 http://us.archive.ubuntu.com/ubuntu jammy-backports InRelease [107 kB]
Get:4 http://us.archive.ubuntu.com/ubuntu jammy-security InRelease [110 kB]
Get:5 http://us.archive.ubuntu.com/ubuntu jammy-updates/main amd64 Packages [852 kB]
Get:6 http://us.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages [796 kB]
Fetched 1,980 kB in 3s (777 kB/s)
Calculating upgrade... Done
The following packages have unmet dependencies: grub-efi-amd64-signed : Depends: grub-efi-amd64-bin (= 2.06-2ubuntu10) but 2.06-2ubuntu14 is to be installed E: Broken packages
This might be a simple fix. I've searched around and tried some of the common fixes eg sudo apt-get install -f and a few others without any change.
Edit: Here's the requested output:
:~$ apt policy grub-efi-amd64-{signed,bin}
grub-efi-amd64-signed:
  Installed: 1.182~22.04.1+2.06-2ubuntu10
  Candidate: 1.187.2+2.06-2ubuntu14
  Version table:
     1.187.2+2.06-2ubuntu14 500 (phased 25%)
        500 http://us.archive.ubuntu.com/ubuntu jammy-updates/main amd64 Packages
 *** 1.182~22.04.1+2.06-2ubuntu10 500
        500 http://us.archive.ubuntu.com/ubuntu jammy-security/main amd64 Packages
        100 /var/lib/dpkg/status
     1.180+2.06-2ubuntu7 500
        500 http://us.archive.ubuntu.com/ubuntu jammy/main amd64 Packages
grub-efi-amd64-bin:
  Installed: 2.06-2ubuntu10
  Candidate: 2.06-2ubuntu14
  Version table:
 *** 2.06-2ubuntu10 500
     2.06-2ubuntu7 500
Auxulum
According to the results of apt policy grub-efi-amd64-{signed,bin} the involved packages are currently undergoing a phased update. They are being held back in most cases, but because this is causing a broken packages error in your Ubuntu it would be OK to update them anyway by running the following command:
sudo apt-get install --only-upgrade `sudo apt-get upgrade | awk 'BEGIN{flag=0} /The following packages have been kept back:/ { flag=1} /^ /{if (flag) print}'`
After doing that you should be able to run sudo apt update && sudo apt upgrade without getting an error message.
karel
  • 122,292
  • 133
  • 301
  • 332
