I'm using Ubuntu 20.04 (I can't upgrade to the next version).
How to prevent the "available updates window" from appearing in front of other opened windows?
I would like it to open minimized completely (like it does in later versions of Ubuntu). I don't want to disable the check of updates.
This behavior is very much frustrating, because it appears in front of other open windows, causing the active window to lose focus, especially when I'm typing something in it...
I need to fix this, it's so frustrating when it changes the focus while I'm typing!
Thanks
You can force it to open minimized with devilspie2 (tutorial repo)
Install: sudo apt install -y devilspie2
Create ~/.config/devilspie2/minimize.lua:
if (get_application_name() == "check-new-release-gtk") then
  minimize();
end
To start automatically create ~/.config/autostart/devilspie2.desktop:
[Desktop Entry]
Name=devilspie2
Exec=devilspie2
Terminal=false
Type=Application
Reboot and it should always open minimized.
Note: this is for the upgrade to 22.04, if you meant software updates then replace check-new-release-gtk with update-manager.
jamedeus
  • 176
