My motherboard bluetooth chip is weaker, and have dongle which gave better range. Previosly I found solution here (long time ago, maybe on ubuntu 18) -> Deactivate internal bluetooth adapter while leaving usb dongle online
With which I excluded motherboard chip, but now on ubuntu 22 i tested is not working. It's modern now, shows 2 adapters, how can I exclude one (motherboard) adapter and choose dongle.
josifoski@josifoski-HP-EliteBook-8460p:~$ lsusb
Bus 002 Device 004: ID 03f0:231d HP, Inc Broadcom 2070 Bluetooth Combo
Bus 002 Device 003: ID 04f2:b230 Chicony Electronics Co., Ltd Integrated HP HD Webcam
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 002: ID 05e3:0612 Genesys Logic, Inc. Hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 012: ID 10c4:8105 Silicon Labs USB OPTICAL MOUSE
Bus 003 Device 010: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
Bus 003 Device 009: ID 05e3:0610 Genesys Logic, Inc. Hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 003: ID 138a:003c Validity Sensors, Inc. VFS471 Fingerprint Reader
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
cat /etc/udev/rules.d/81-bluetooth-hci.rules SUBSYSTEM=="usb", ATTRS{idVendor}=="03f0", ATTRS{idProduct}=="231d", ATTR{authorized}="0"
Any help
josifoski
  • 123
To select a default bluetooth controller you can use the bluetoothctl command which directly talks to the bluez stack that Ubuntu uses by default:
bluetoothctl list
Which will list your bluetooth controllers and their MAC address, then select the one you want as the default using it's MAC address:
# replace with your controller's mac address
bluetoothctl select 00:11:22:33:44:55
You may have to turn the power on your bluetooth controller after setting the default controller, which you can accomplish using this command:
bluetoothctl power on
You can find more information here: https://ubuntu.com/core/docs/bluez/reference/pairing/introduction
In general though your solution should involve going through bluez rather than through udev.
Disabling a bluetooth adapter at the kernel level is overkill. I have multiple bluetooth controllers connected to my system and have never had to mess around with udev to get them working.
