Running lspci -vvv | grep -A 10 -i "Network Controller" produces:
02:00.0 Network controller: Realtek Semiconductor Co., Ltd. Device b852
    Subsystem: Lenovo Device 4853
    Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
    Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
    Interrupt: pin A routed to IRQ 69
    IOMMU group: 11
    Region 0: I/O ports at 2000 [size=256]
    Region 2: Memory at fd600000 (64-bit, non-prefetchable) [size=1M]
    Capabilities: <access denied>
    Kernel modules: rtw_8852be
Running neofetch produces:
 .-/+oossssoo+/-.               sean@sean-IdeaPad-1-15ALC7
        `:+ssssssssssssssssss+:`           --------------------------
      -+ssssssssssssssssssyyssss+-         OS: Ubuntu 22.04.1 LTS x86_64
    .ossssssssssssssssssdMMMNysssso.       Host: 82R4 IdeaPad 1 15ALC7
   /ssssssssssshdmmNNmmyNMMMMhssssss/      Kernel: 5.15.0-58-generic
  +ssssssssshmydMMMMMMMNddddyssssssss+     Uptime: 11 mins
 /sssssssshNMMMyhhyyyyhmNMMMNhssssssss/    Packages: 1746 (dpkg), 12 (snap)
.ssssssssdMMMNhsssssssssshNMMMdssssssss.   Shell: bash 5.1.16
+sssshhhyNMMNyssssssssssssyNMMMysssssss+   Resolution: 1920x1080
ossyNMMMNyMMhsssssssssssssshmmmhssssssso   DE: GNOME 42.5
ossyNMMMNyMMhsssssssssssssshmmmhssssssso   WM: Mutter
+sssshhhyNMMNyssssssssssssyNMMMysssssss+   WM Theme: Adwaita
.ssssssssdMMMNhsssssssssshNMMMdssssssss.   Theme: Yaru [GTK2/3]
 /sssssssshNMMMyhhyyyyhdNMMMNhssssssss/    Icons: Yaru [GTK2/3]
  +sssssssssdmydMMMMMMMMddddyssssssss+     Terminal: gnome-terminal
   /ssssssssssshdmNNNNmyNMMMMhssssss/      CPU: AMD Ryzen 7 5700U with Radeon G
    .ossssssssssssssssssdMMMNysssso.       GPU: AMD ATI 04:00.0 Lucienne
      -+sssssssssssssssssyyyssss+-         Memory: 1960MiB / 9819MiB
            .-/+oossssoo+/-.
Running sudo lshw -C network produces:
  *-network UNCLAIMED
       description: Network controller
       product: Realtek Semiconductor Co., Ltd.
       vendor: Realtek Semiconductor Co., Ltd.
       physical id: 0
       bus info: pci@0000:02:00.0
       version: 00
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress cap_list
       configuration: latency=0
       resources: ioport:2000(size=256) memory:fd600000-fd6fffff
  *-network
       description: Ethernet interface
       physical id: 9
       bus info: usb@1:2
       logical name: usb0
       serial: be:29:eb:c1:b0:14
       capabilities: ethernet physical
       configuration: autonegotiation=off broadcast=yes driver=rndis_host driverversion=5.15.0-58-generic duplex=half firmware=RNDIS device ip=192.168.42.238 link=yes multicast=yes port=twisted pair
Running lsppci -knn | grep Net -A3 produces:
02:00.0 Network controller [0280]: Realtek Semiconductor Co., Ltd. Device [10ec:b852]
    Subsystem: Lenovo Device [17aa:4853]
03:00.0 Non-Volatile memory controller [0108]: Intel Corporation Device [8086:f1aa] (rev 03)
On startup, a line of text is displayed reading rtw89_8852be 0000:02:00.0: failed to setup chip information
I have tried deleting and reinstalling to wifi driver from https://github.com/lwfinger/rtw89 but it didn't work.
I'm thinking maybe my driver is just incompatible with Ubuntu, but I'm not sure.
ANY HELP IS APPRECIATED!
Let me know if you need more info. I will be actively replying to messages here. Thank you in advance!
After updating from Ubuntu 22.04 LTS to Ubuntu 22.10 the driver mentioned in this question didn't work for me anymore as well.
However, using this older driver fixed the issue.
git clone https://github.com/HRex39/rtl8852be.git -b dev
cd rtl8852be
make
sudo make install
sudo modprobe 8852be
NotTheDr01ds
  • 22,082
