I'm currently trying to upgrade from 22.04 to 22.10 (just because I'd like to), and for some reason, I have 20 packages that no matter what I try, they will not update, which is holding me back from upgrading. I've tried everything it says to update them, delete them, etc. and nothing. Any advice?
When I run sudo apt update, I get this result:
    Get:1 http://security.ubuntu.com/ubuntu jammy-security InRelease [110 kB]
    Hit:2 http://us.archive.ubuntu.com/ubuntu jammy InRelease
    Hit:3 https://download.docker.com/linux/ubuntu jammy InRelease
    Get:4 http://us.archive.ubuntu.com/ubuntu jammy-updates InRelease [114 kB]
    Hit:5 https://cloud.r-project.org/bin/linux/ubuntu focal-cran40/ InRelease
    Get:6 http://us.archive.ubuntu.com/ubuntu jammy-backports InRelease [99.8 kB]
    Hit:7 https://ppa.launchpadcontent.net/deadsnakes/ppa/ubuntu jammy InRelease
    Get:8 http://security.ubuntu.com/ubuntu jammy-security/main amd64 DEP-11 Metadata [41.4 kB]
     Get:9 http://us.archive.ubuntu.com/ubuntu jammy-updates/main amd64 DEP-11 Metadata [102 kB]
    Get:10 http://security.ubuntu.com/ubuntu jammy-security/universe amd64 DEP-11 Metadata [13.3 kB]
    Get:11 http://us.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 DEP-11 Metadata [265 kB]
    Get:12 http://us.archive.ubuntu.com/ubuntu jammy-updates/multiverse amd64 DEP-11 Metadata [940 B]
    Get:13 http://us.archive.ubuntu.com/ubuntu jammy-backports/universe amd64 DEP-11 Metadata [12.5 kB]
    Fetched 759 kB in 1s (540 kB/s)
    Reading package lists... Done
    Building dependency tree... Done
    20 packages can be upgraded. Run 'apt list --upgradable' to see them.
    W: https://cloud.r-project.org/bin/linux/ubuntu/focal-cran40/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
When I run sudo apt-get upgrade, I get this:
Calculating upgrade... Done
The following packages have been kept back:
  libinput-bin libinput10 python3-software-properties r-base r-base-core
  r-base-dev r-cran-class r-cran-cluster r-cran-foreign r-cran-lattice
  r-cran-mass r-cran-matrix r-cran-mgcv r-cran-nlme r-cran-nnet r-cran-rpart
  r-recommended software-properties-common software-properties-gtk
  ubuntu-advantage-tools
0 upgraded, 0 newly installed, 0 to remove and 20 not upgraded.
When I run sudo do-release-upgrade, I get this:
Checking for a new Ubuntu release
Please install all available updates for your release before upgrading.
Any advice would be wonderful.
Thanks!
EDIT: After running sudo apt install packagename I get this:
 r-base-core : Depends: libicu66 (>= 66.1-1~) but it is not installable
Take a look and see if you can locate the problem.
  1. You're running a 22.04 ("jammy") system
  2. You have a source that says https://cloud.r-project.org/bin/linux/ubuntu focal-cran40/
See it? "focal" instead of "jammy"
You are running R packages that are for the wrong release of Ubuntu AND from a non-Ubuntu source. Double-whammy. That's why they are "kept back". That's why you are seeing the "impossible situation" paragraph.
  1. Preserve your data.
  2. Uninstall ALL R packages from that wrong-version source. (https://cloud.r-project.org/bin/linux/ubuntu focal-cran40/)
  3. Disable or delete that source.
  4. Run sudo apt update because you just changed your sources.
  5. Run sudo apt clean to remove those wrong-version packages from your local cache.
  6. Re-install the R packages. Without that wrong-version source, your system will install them from the compatible Ubuntu repositories.
This should solve most of your problems.
user535733
  • 68,493
