I did a normal update using gui since I got a popup. It installed most stuff, but said it couldn't install everything. So I pressed partial installation, thinking I could install the rest after a restart. It didn't look that important the things that where not able to install.
After the restart it only showed on my main display, my side monitors where showing "no input". After a removing nvidia drivers and using the xorg drivers, and a reboot, it worked once again. After this I installed nvidia-driver-525 (proprietary, tested) again and it worked fine. After the first restart no commands, like nvtop or nvidia-smi worked. Had issues communicating with the drivers.
After reinstalling the nvidia drivers it still have issues connecting to the drivers. It do find my card, 1070, when I go to additional drivers and updates. And since I'm using a non IGPU cpu, it shows picture.
So my conclusion is that something went wrong during the update, or one of the now upgradable is very much needed. This is the packages that where not able, and still is unable to install:
    zellogi@zellogi-PC:~$ apt list --upgradable
Listing... Done
gnome-remote-desktop/jammy-updates 42.7-0ubuntu1 amd64 [upgradable from: 42.4-0ubuntu1]
language-selector-common/jammy-updates,jammy-updates 0.219.1 all [upgradable from: 0.219]
language-selector-gnome/jammy-updates,jammy-updates 0.219.1 all [upgradable from: 0.219]
systemd-hwe-hwdb/jammy-updates,jammy-updates 249.11.2 all [upgradable from: 249.11.1]
update-notifier-common/jammy-updates,jammy-updates 3.192.54.3 all [upgradable from: 3.192.54]
update-notifier/jammy-updates 3.192.54.3 amd64 [upgradable from: 3.192.54]
No games or other gpu-workloads seems to work (media, transcoding and VMs). So question is, how do I continue? What info do you need to help me?
Edit: Adding command;
zellogi@zellogi-PC:~$ nvidia-settings
ERROR: NVIDIA driver is not loaded
(nvidia-settings:45719): GLib-GObject-CRITICAL **: 14:18:56.056: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
** (nvidia-settings:45719): CRITICAL **: 14:18:56.057: ctk_powermode_new: assertion '(ctrl_target != NULL) && (ctrl_target->h != NULL)' failed
ERROR: nvidia-settings could not find the registry key file or the X server is not accessible. This file should have been installed along with this driver at /usr/share/nvidia/nvidia-application-profiles-key-documentation. The application profiles will continue to work, but values cannot be prepopulated or validated, and will not be listed in the help text. Please see the README for possible values and descriptions.
** Message: 14:18:56.076: PRIME: No offloading required. Abort ** Message: 14:18:56.076: PRIME: is it supported? no
I'm not sure how to read this. Something failed.
