For my network I have setup two VLans (VLan Ids: 1 and 2) on the switch. My ubuntu core 22.04.1 machine is connected to the switch through one tagged port that allows for VLan 1 and VLan 2 traffic. This machine will later be hosting docker containers that run dhcp, dns, OpenLDAP, etc. I would like to use netplan on my ubuntu machine, since it provides me with a nice overview about my network configuration. I want to achieve:
- to have an ip address 192.168.10.101/24 in VLan 1 that is reachable from other hosts in VLan 1
- to have an ip address 192.168.20.101/24 in VLan 2 that is reachable from other hosts in VLan 2
- routing for the ubuntu machine to other hosts in both subnets 192.168.10.0/24 and 192.168.20.0/24 through the gateways 192.168.10.1 and 192.168.20.1 respectively
- routing to a default gateway 192.168.10.1 for the ubuntu machine to connect to the Internet
The file /etc/netplan/00-installer-config.yml looks like:
network:
version: 2
ethernets:
enp5s0:
dhcp4: false
enp6s0:
dhcp4: false
optional: true
vlans:
vlan.1:
link: enp5s0
addresses:
- 192.168.10.101/24
nameservers:
addresses:
- 192.168.10.116
routes:
- to: default
via: 192.168.10.1
metric: 100
vlans:
vlan.2:
link: enp5s0
addresses:
- 192.168.20.101/32
The output of ip route is:
default via 192.168.10.1 dev vlan.1 proto static metric 100
172.17.0.0/16 dev docker0 proto kernel scope link src 172.17.0.1
192.168.10.0/24 dev vlan.1 proto kernel scope link src 192.168.10.101
This configuration (applied with sudo netplan apply) provides me already very close to what I want to do:
- From the ubuntu machine I can
- ssh into a machine on the 192.168.10.0/24 subnet
- ssh into a machine on the 192.168.20.0/24 subnet
- reach the Internet
- From a host in the 192.168.10.0/24 subnet I can reach the ubuntu machine through 192.168.10.101
- From a host in the 192.168.20.0/24 subnet I can reach the ubuntu machine through 192.168.10.101
What I am missing are the following:
- From a host in the 192.168.10.0/24 subnet to reach 192.168.20.101
- From a host in the 192.168.20.0/24 subnet to reach 192.168.20.101 as well.
Looking at the netplan configuration above, I assume this is due to the 192.168.20.101/32 that does not allow to reach this IP from other hosts in both subnets. I already tried to define the address with 192.168.20.101/24, but that resulted in not being able to reach any other host on the 192.168.20.0/24 subnet from the ubuntu machine.
Can somebody please help me finding out what I did wrong that prevents the ubuntu machine from being reachable through 192.168.20.101?
Can I even do this with netplan or do I need to do some steps manually after applying the configuration?
