Long story short - I'm trying to uninstall broken wine after failed update. I've some problems with broken packages - it gives something like "out of incoming" - I use spanish distribution of OS. So for that reason I'm unable to run wine correctly. After aparenting correct instalation wine doesn't run, because wine32 I'm not able to install.
What I need is delete everything related with wine and try installing from zero. All related stuff seen at a lot of sites was useless.
I've ubuntu 20.04
It gives this:
unlock@Acer-Aspire-ES1-331:~$ sudo apt-get install wine32
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies: wine32:i386 : Depends: libwine:i386 (= 5.0-3ubuntu1) but it is not going to be installed E: Unable to correct problems, you have held broken packages.
This is a few longer output from apt-update:
unlock@Acer-Aspire-ES1-331:~$ sudo apt update
[sudo] password for unlock:
Hit:1 http://es.archive.ubuntu.com/ubuntu focal InRelease
Hit:2 http://es.archive.ubuntu.com/ubuntu focal-security InRelease
Hit:3 https://dl.winehq.org/wine-builds/ubuntu focal InRelease
Hit:4 http://ppa.launchpad.net/webupd8team/y-ppa-manager/ubuntu focal InRelease
Hit:5 http://ppa.launchpad.net/zorinos/wine-testing/ubuntu focal InRelease
Hit:6 https://repositories.intel.com/graphics/ubuntu focal InRelease
22 packages can be upgraded. Run 'apt list --upgradable' to see them.
W: Target Packages (main/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list:54 and /etc/apt/sources.list:58
W: Target Packages (main/binary-i386/Packages) is configured multiple times in /etc/apt/sources.list:54 and /etc/apt/sources.list:58
W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:54 and /etc/apt/sources.list:58
W: Target Translations (main/i18n/Translation-en_US) is configured multiple times in /etc/apt/sources.list:54 and /etc/apt/sources.list:58
W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list:54 and /etc/apt/sources.list:58
W: Target Translations (main/i18n/Translation-es) is configured multiple times in /etc/apt/sources.list:54 and /etc/apt/sources.list:58
W: Target DEP-11 (main/dep11/Components-amd64.yml) is configured multiple times in /etc/apt/sources.list:54 and /etc/apt/sources.list:58
W: Target DEP-11 (main/dep11/Components-all.yml) is configured multiple times in /etc/apt/sources.list:54 and /etc/apt/sources.list:58
W: Target DEP-11-icons-small (main/dep11/icons-48x48.tar) is configured multiple times in /etc/apt/sources.list:54 and /etc/apt/sources.list:58
W: Target DEP-11-icons (main/dep11/icons-64x64.tar) is configured multiple times in /etc/apt/sources.list:54 and /etc/apt/sources.list:58
W: Target DEP-11-icons-hidpi (main/dep11/icons-64x64@2.tar) is configured multiple times in /etc/apt/sources.list:54 and /etc/apt/sources.list:58
W: Target CNF (main/cnf/Commands-amd64) is configured multiple times in /etc/apt/sources.list:54 and /etc/apt/sources.list:58
W: Target CNF (main/cnf/Commands-all) is configured multiple times in /etc/apt/sources.list:54 and /etc/apt/sources.list:58
W: Target Packages (main/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list:54 and /etc/apt/sources.list.d/winehq-focal.sources:1
W: Target Packages (main/binary-i386/Packages) is configured multiple times in /etc/apt/sources.list:54 and /etc/apt/sources.list.d/winehq-focal.sources:1
W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:54 and /etc/apt/sources.list.d/winehq-focal.sources:1
W: Target Translations (main/i18n/Translation-en_US) is configured multiple times in /etc/apt/sources.list:54 and /etc/apt/sources.list.d/winehq-focal.sources:1
W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list:54 and /etc/apt/sources.list.d/winehq-focal.sources:1
W: Target Translations (main/i18n/Translation-es) is configured multiple times in /etc/apt/sources.list:54 and /etc/apt/sources.list.d/winehq-focal.sources:1
W: Target DEP-11 (main/dep11/Components-amd64.yml) is configured multiple times in /etc/apt/sources.list:54 and /etc/apt/sources.list.d/winehq-focal.sources:1
W: Target DEP-11 (main/dep11/Components-all.yml) is configured multiple times in /etc/apt/sources.list:54 and /etc/apt/sources.list.d/winehq-focal.sources:1
W: Target DEP-11-icons-small (main/dep11/icons-48x48.tar) is configured multiple times in /etc/apt/sources.list:54 and /etc/apt/sources.list.d/winehq-focal.sources:1
W: Target DEP-11-icons (main/dep11/icons-64x64.tar) is configured multiple times in /etc/apt/sources.list:54 and /etc/apt/sources.list.d/winehq-focal.sources:1
W: Target DEP-11-icons-hidpi (main/dep11/icons-64x64@2.tar) is configured multiple times in /etc/apt/sources.list:54 and /etc/apt/sources.list.d/winehq-focal.sources:1
W: Target CNF (main/cnf/Commands-amd64) is configured multiple times in /etc/apt/sources.list:54 and /etc/apt/sources.list.d/winehq-focal.sources:1
W: Target CNF (main/cnf/Commands-all) is configured multiple times in /etc/apt/sources.list:54 and /etc/apt/sources.list.d/winehq-focal.sources:1
karel
  • 122,292
  • 133
  • 301
  • 332
