I have a Dell Xps 13 l321x and I was using windows 10 normally, I then decide to install Ubuntu as the main OS, I downloaded it and do the normal install of Ubuntu in MBR since my laptop is MBR only, I burn it with Rufus in MBR mode, I installed Ubuntu successfully but after I removed the system to boot into Ubuntu, it shows operation system not found. I tried every, tried manual partitioning still not working.. pls help
Asked
Active
Viewed 637 times
check within your BIOS to see if Ubuntu is listed in the boot section. if Ubuntu is listed mark that as first boot.
if Ubuntu is not listed reinstall Ubuntu paying careful attention to the setup up which will require /uefi partition formatted to fat32. this is regardless of using legacy mode for the system ...
