The goal is to activate dedicated graphic card to play game. I updated kernel to install nvidia driver.
I can boot the system in recovery mode but no network available in it.
bellow, this is what i see after reboot after installing nvidia driver. and it does not boot further.
if i purge nvidia via recovery mode, everything gets back to normal(boots properly)
i have lenovo yoga with i7 with integrated and dedicated graphic cards. all time before i used integrated card with no problems on default drivers. But i wanted to play a game that requires more GPU power and i want to activate it. GPU is geforce 1050 mobile.
nothing worked and i updated kernel via ubuntu mainline kernel installer as i found somewhere.
seems like nvidia driver changes mounting setting but i'm not sure.
How to install nvidia properly?
8.3389251 IPI shorthand broadcast: enabled
0.3309601 sched_clock: Marking stable (324949169, 5919881)->(362378257, -31502807)
8.3313731 registered taskstats version
0.3316921 Loading compiled-in X.509 certificates
8.3326311 Loaded X.509 cert "Build time autogenerated kernel key: 8732c115dd832bccb9499572a2159deee14867'
8.3330481 Loaded X.599 cert "Canonical Ltd. Live Patch Signing: 14d134d1a87c137625abec839ef2b5212496969
0.3334441 Loaded X.509 cert 'Canonical Ltd. Kernel Module Signing: 88752568a1e73731163a466ad7b78a858c19'
8.3334861 blacklist: Loading compiled-in revocation X.589 certificates
0.333536] Loaded X.589 cert
0.3337861 Zswap: loaded using pool Izo/zbud
'Canonical Ltd. Secure Boot Signing: 61482a2830dBab2ad5a18b7258da9833ddcef8'
B.3348881 Key type fscrypt registered
8.3341221 Kev tupe fscrypt-provisioning registered
8.3346591 Key type encrypted registered
8.334681] AppArmor: AppArmor shal policy hashing enabled
8.3361961 integrity: Loading X.509 certificate: UEFI:db
0.336261] integrity: Loaded X,589 cert 'Microsoft Windous Production PCA 2011: a92902398e16c49778cd98f99e4f9ael7c55af53'
0.3363871 integrity: Loading X.589 certificate: UEF1: db
0.3363491 integrity: Loaded X.509 cert 'Microsoft Corporation UEFI CA 2811: 13adbf4389bd82789c8cd54f316ed522988a1bd4'
0.3363933 integrity: Loading X.589 certificate: UEFI:b
8.9964251 Integrity: Loaded X.509 cert "7KYoga730-15: 9d9ed4dd5c8f379249c64e13725dbed7'
0.337817] ima: No TPM chip found, activating TPM-bypass!
0.3378471 Loading compiled-in module X.509 certificates
8.338266] Loaded X.509 cert 'Build time autogenerated kernel key: 8732c115dd832bccb9499572a2159deee14867'
B.3383121 ima: Allocated hash algorithm: shal
0.338338] ima: No architecture policies found
B.3383821 evm: Initialising EVM extended attributes:
B.338487] evm: security.selinux
0.338436] evm: security.SMACK64
0.3384513 evm: security. SMACK64EXEC B.338469] evm: security.SMACK64TRANSMUTE
8.338493] evm: security. SMACK64MMAP
0.338510] evm: security. apparmor
0.339744] evm: security. ima
0.348968] evm: security.capability
B.342175] evm: HMAC attrs: Bx1
0.3458663 PM:
Magic number: 7:572:182
0.347288] acpi device:41: hash matches
B.348615] RAS: Correctable Errors collector initialized.
B.349942] md: Waiting for all devices to be available before autodetect
0.351192] md: If you don't use raid, use raid-noautodetect
0.3524831 md: Autodetecting RAID arrays.
0.3536191 md: autorun ..
0.354885] md:
... autorun DONE.
0.356312] /dev/root: Can't open blockdev
B.3575461 VFS: Cannot open root device "UUID-be5b2da7-a51e-46dB-9f9f-Scab82dab85f" or unknoun-block(B,B): error -6
B.358895] Please append a correct "root=" boot option; here are the available partitions:
8.3682111 Kernel panic - not syncing: VFS: Unable to mount root fs on unknoun-block(®,®)
B.3615473 CPU: 1 PID: 1 Comm: Suapper/0 Not tainted 6.1.7-060187-generic #282301181200
8.3629581 Harduare name: LENOVO 81CU/LNVNB161216, BIOS 7KCN33H(V1, 14) 12/29/2020
0.3643251 Call Trace:
0.365682] <TASK>
0.3678441
shou_stack+8x4e/0x61
0.368381] dump_stack_1v1+8x4a/Bx6f
0.3697141 dump_stack+8x10/8x18
0.371069] panic+0x16e/9×31f
0.372375] mount_block_root+8x151/8x1f6
0.373681]
mount_root+0×94/Bxa3
0.375010] prepare_namespace+0×13f/8×181
0.3762961
kernel_init_freeable+Bx11e/0x137
0.3775563
? rest_init+8x180/8x100
0.3788691 kernel_-init+8x1b/Bx170
0.3801161 ? rest_init+8x108/0x100
0.381346] ret_from_fork+0x1f/Bx30
0.3826851
</TASK>
9.3838591 Kernel Offset: 8x19880000 from Bxffffffff81000000 (relocatlon range: Bxffffffffe000000-Bxffffffffbfffffff)
0.3852291
---[ end Kernel panic - not syncing: VFS; Unable to mount root fs on unknown-block(0,0)
