After using Ubuntu 22.10 and I restart the PC I run windows 10. The time shown is different from the current time. Hence every time I come to Windows from Ubuntu I have to manually change the time. Please help with this issue.
David DE
  • 2,316
If you're using the default Ubuntu user interface, then you just go into time settings and force the automatic sync. Once you pick the time zone it should boot up and set it right when the ntp loads up in the system servces.
Ubuntu looks at time very differently... As a UTC+offset, where Windows expects the system clock to be your local time, Ubuntu will set the system clock to UTC. But, if the sync and timezone is on then you shouldn't have a problem but for a moment. Windows syncs as well, because if the clock is off by even a full second it breaks all sorts of things to do with encryption and networking.
sean
  • 546
