I use Ubuntu 22.04.1 LTS. However, after trying to sudo apt install ukui-desktop-environment the installation was not successful. Sadly, doing sudo apt upgrade doesn't work either. I get the following message.
Reading package lists... Done
Building dependency tree... Done
You might want to run 'apt --fix-broken install' to correct these.
ukui-control-center : Depends: kylin-nm (>= 3.1.1-2021+1029.1) but it is not installed
Depends: ukui-media (>= 3.0.0-64) but it is not installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
I tried many other options including the following various ones, individually.
sudo apt install -f
sudo apt remove --purge ukui-desktop-environment
sudo dpkg --configure --force-overwrite -a
sudo dpkg --configure -a
sudo apt dist-upgrade -y
Nothing works. I am pretty much stuck with:
Honestly, at this point, I no longer want the new package. I just want to be able to go back to how things were. How can I undo everything and just get back my original ubuntu?
