I have just installed Ubuntu 22.04 and tried to install Sagemath from
https://sagemanifolds.obspm.fr/install_ubuntu.html
with the following commands: sudo apt install sagemath-jupyter
Unfortunately a message with writing I have unmet dependencies appeared:
sudo apt-get install  sagemath
Reading package lists... Done
Building dependency tree... Done
The following packages have unmet dependencies: python3-rpy2 : Depends: python3 (< 3.9) but 3.10.6-1~22.04 is to be installed E: Unable to correct problems, you have held broken packages.
The command sudo apt update gives the following message in the end that might be helpful:
W: https://cloud.r-project.org/bin/linux/ubuntu/focal-cran40/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
My python version is python 3.10.6, yet I have installed an older version of python 3.7 as it is written on the above message. When I tried to install again the same message occured.
Furthermore, I tried to build Sagemath 9.7 from source as in the above site but my laptop stacks at the final command
MAKE="make -j8" make
at some point and I forced to shut it down. Could you please help me?
Try this:
sudo dpkg -l | grep '^.[^i]'
Then for each packages which have something other than ii in the first and second column, or an ..R in the third column, remove them using:
sudo dpkg --remove --force-all package_name
sudo apt-get clean
sudo apt-get update
sudo apt-get --fix-broken install
Hopefully, this should fix the broken package.
rusty
  • 16,917
I used sudo aptitude install sagemath
and gave me more than one solution to the unmet dependencies. I kept installing packages with aptitude and finally sagemath is now installed.
Thank you all!
