I am on Ubuntu 22.04
$ sudo 1shw -class network
*-network UNCLAIMED
description: Network controller
product: Wi-Fi 6 AX210/AX211/AX411 160MHz
vendor: Intel Corporation
physical id: 0
bus info: pci@0000:06:00.0
version: 1a
width: 64 bits
Clock: 33MHz
capabilities: pm msi pciexpress msix cap_list
configuration: latency=0
resources: memory:fc400000-fc403fff
*-network UNCLAIMED description: Ethernet controller product: Ethernet Controller 1225-V vendor: Intel Corporation physical id: 0 bus info: pci@0000:09:00.0 version: 03 width: 32 bits clock: 33MHZ capabilities: pm msi msix pciexpress bus_master cap list configuration: latency-0 resources: memory: fc200000-fc2fffff memory: fc300000-fc303fff
$ lspci -knn I grep Net -A3; rfkill list
06:00.0 Network controller (0280]: Intel Corporation Wi-Fi 6 AX210/AX211/AX411 160MHz [8086:2725] (rev 1a)
    Subsystem: Intel Corporation Wi-Fi 6 AX210 160MHz [8086:0024]
09:00.0 Ethernet controller (0200]: Intel Corporation Ethernet Controller I225-V (8086:153] (rev 03)
    Subsystem: ASUSTeK Computer Inc. Ethernet Controller I225-V (1043:87d2)
How do I associate the Network controller and Ethernet controller?
EDIT
$ sudo dpkg -s linux-modules-extra-$(uname -r) | grep Status
Output:
dpkg-query: package 'Linux-modules-extra-5.15.0-58-generic' is not installed and no information is available
Use dpkg - -info (= dpkg-deb --info) to examine archive files.
chicken
  • 61
I finally fixed the problem!
Here is what I did:
  1. spam the shift key on startup to get into the grub menu
  2. go to advanced options
  3. click on recovery mode for a different linux kernel that is not having issues
  4. click enable networking
  5. click fix broken packages
  6. click resume boot
Bam! Fixed!
chicken
  • 61
Some kernel packages are not installed.
You can fix it by running
sudo apt install --reinstall linux-generic
This meta package should install all kernel modules.
Pilot6
  • 92,041
