I have an 8GB swap file under /swapfile1 and I have to load it manually in the terminal every time I log in. I tried to modify fstab following the advice given in this thread Adding a new swap file. How to edit fstab to enable swap after reboot? with no success. What do I need to add to fstab to make this work?
Here is my existing fstab file:
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
/dev/mapper/nvme0n1p6_crypt / ext4 errors=remount-ro 0 1
# /boot was on /dev/nvme0n1p5 during installation
UUID=0caeaa04-232f-4181-87a6-cab787ef6d0c /boot ext4 defaults 0 2
# /boot/efi was on /dev/nvme0n1p1 during installation
UUID=666E-4F0F /boot/efi vfat umask=0077 0 1
