I just upgraded today from 18.04 to 20.04, I am not sure if there was a mistake made in the upgrade. I am not able to upgrade a lib and do-release-upgrade to the newer version due to this lib.
I have included some outputs below for a lib thats isnt upgrading and allowing me to continue:
user@server:~$ sudo apt full-upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following packages were automatically installed and are no longer required:
  argyll argyll-ref deluge-gtk dh-python g++-7 gcc-8-base:i386 gedit-plugin-dashboard gedit-plugin-zeitgeist gir1.2-appindicator3-0.1 gir1.2-clutter-gst-3.0 gir1.2-gepub-0.6 gir1.2-zeitgeist-2.0
  gtk2-engines-xfce gyp ipset lib32gcc1 libappindicator1 libatomic1:i386 libavcodec57 libavdevice57 libavfilter6 libavformat57 libavresample3 libavutil55 libboost-python1.65.1 libbsd0:i386 libc-ares2
  libclang-common-10-dev libclang-common-12-dev libclang-cpp12 libcrystalhd3 libcue1 libdleyna-core-1.0-3 libdouble-conversion1 libdrm-amdgpu1:i386 libdrm-dev libdrm-intel1:i386 libdrm-nouveau2:i386
  libdrm-radeon1:i386 libdrm2:i386 libdvdread4 libedit2:i386 libegl1-mesa-dev libelf1:i386 libenca0 libexpat1:i386 libffi6:i386 libffi7:i386 libfluidsynth1 libfluidsynth2 libgegl-0.3-0 libgepub-0.6-0
  libgfortran4 libgit2-26 libgl1:i386 libgl1-mesa-dri:i386 libgl1-mesa-glx:i386 libglapi-mesa:i386 libgles2-mesa-dev libglvnd-core-dev libglvnd0:i386 libglx-mesa0:i386 libglx0:i386 libgnustep-base1.25
  libgssdp-1.0-3 libgtkspell3-3-0 libgupnp-1.0-4 libhttp-parser2.7.1 libindicator7 libinstpatch-1.0-2 libipset13 libipset3 libiptcdata0 libjs-async libjs-inherits libjs-node-uuid libjte1 liblinear3
  liblivemedia62 libllvm10:i386 libllvm12:i386 libllvm8 libllvm9 libllvm9:i386 liblua5.1-0 libluajit-5.1-2 libluajit-5.1-common libmagick++-6.q16-7 libmicrodns0 libmikmod3
  libmono-system-runtime-interopservices-runtimeinformation4.0-cil libmysofa0 libmysqlclient20 libnfs11 libosinfo-1.0-0 libpciaccess-dev libpciaccess0:i386 libplacebo4 libportmidi0 libpostproc54
  libprotobuf-lite10 libpython3.6-dev libqrencode3 libsdl-mixer1.2 libsdl-ttf2.0-0 libsensors5:i386 libsmpeg0 libstd-rust-1.59 libstdc++-7-dev libstdc++6:i386 libswresample2 libswscale4 libthunarx-2-0
  libtinfo-dev libtinfo5:i386 libupnp6 libuv1-dev libvulkan1:i386 libwayland-bin libwayland-client0:i386 libwayland-dev libwnck-common libwnck22 libx11-6:i386 libx11-xcb-dev libx11-xcb1:i386 libx264-152
  libx265-146 libx86emu1 libxau6:i386 libxcb-dri2-0:i386 libxcb-dri2-0-dev libxcb-dri3-0:i386 libxcb-dri3-dev libxcb-glx0:i386 libxcb-glx0-dev libxcb-present-dev libxcb-present0:i386 libxcb-randr0:i386
  libxcb-randr0-dev libxcb-render0-dev libxcb-shape0-dev libxcb-shm0:i386 libxcb-sync-dev libxcb-sync1:i386 libxcb-xfixes0:i386 libxcb-xfixes0-dev libxcb1:i386 libxdamage-dev libxdamage1:i386 libxdmcp6:i386
  libxext6:i386 libxfconf-0-2 libxfixes-dev libxfixes3:i386 libxinerama1:i386 libxmlb1 libxshmfence-dev libxshmfence1:i386 libxss1:i386 libxxf86vm-dev libxxf86vm1:i386 mesa-common-dev mesa-vulkan-drivers:i386
  orage orage-data osinfo-db php7.2-cli php7.2-common php7.2-json php7.2-mbstring php7.2-opcache php7.2-readline python-asn1crypto python-attr python-automat python-cairo python-constantly python-crypto
  python-dnspython python-gi python-glade2 python-gobject python-gobject-2 python-gtk2 python-hyperlink python-incremental python-mako python-markupsafe python-notify python-pam python-pyasn1 python-pygame
  python-serial python-twisted-bin python-xdg python-zope.interface python3-numpy python3-pygame python3-simplegeneric python3.6-dev qt4-doc qt4-qmake qtcore4-l10n shim timgm6mb-soundfont x11proto-damage-dev
  x11proto-fixes-dev x11proto-xf86vidmode-dev x11vnc-data xfce4-mount-plugin xserver-xorg-legacy-hwe-18.04 xubuntu-icon-theme
Use 'sudo apt autoremove' to remove them.
# News about significant security updates, features and services will
# appear here to raise awareness and perhaps tease /r/Linux ;)
# Use 'pro config set apt_news=false' to hide this and future APT news.
The following packages have been kept back:
  mesa-opencl-icd
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
And some details on unupgraded lib:
user@server:~$ apt list --upgradable -a
Listing... Done
mesa-opencl-icd/focal-updates,focal-security 21.2.6-0ubuntu0.1~20.04.2 amd64 [upgradable from: 20.0.8-0ubuntu1~18.04.1]
mesa-opencl-icd/now 20.0.8-0ubuntu1~18.04.1 amd64 [installed,upgradable to: 21.2.6-0ubuntu0.1~20.04.2]
mesa-opencl-icd/focal 20.0.4-2ubuntu1 amd64
Could I simply remove that lib? Any advice is welcome.
Before removing mesa-opencl-icd run a simulation of what removing this package would do without actually removing anything. Note that this command should not be run as root or prefaced with sudo because it is just a simulation.
apt remove --simulate mesa-opencl-icd
If you can't remove mesa-opencl-icd you can simply upgrade it with sudo apt install mesa-opencl-icd
karel
  • 122,292
  • 133
  • 301
  • 332
