I recently installed Ubuntu 20.04.1 LTS using a Live USB on to my Macbook air from 2015 (in ubuntu hardware model reads "Apple inc.MacbookAir7,2"
Upon successful installation I noticed I couldn't access anything involving wifi. Thru my research I found that it is most likely is the wifi card though I am unsure.
I am unable to connect to wifi or hardwire an internet connection without purchasing the proper ethernet adapter for mac. Which I am willing to do if it can resolve the issue. However I wont be able to provide data that appears thru command line (at least not as detailed) here since I am posting on a different machine.
In other posts looking to resolve the same/similar issue it has been suggested to use a thumb drive between to different devices to install a driver. However they were rather outdated and were running on ubuntu 15.
Update:
when running the lspci -nnk | grep 0280 -A3
command it says I have a BCM4360 802.11ac [14e4:43a0] (rev 03)
kernel driver in use: bcma-pci-bridge
