I tried to install apktool recently using sudo apt install apktool but I keep getting this error, I am using kali linux release 2022.4
dpkg: error processing package python3-protobuf (--configure):
 dependency problems - leaving unconfigured
 python3
 hashcat-data
 criu
 python3-protobuf
needrestart is being skipped since dpkg has failed
Anyone knows how to fix this?
Full error:
Reading package lists... Done
Building dependency tree... Done
apktool is already the newest version (2.6.1+dfsg.1-2).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
4 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up python3 (3.10.6-1) ...
running python rtupdate hooks for python3.10...
dpkg-query: package 'command-not-found' is not installed
Use dpkg --contents (= dpkg-deb --contents) to list archive files contents.
Traceback (most recent call last):
  File "/usr/bin/py3clean", line 210, in <module>
    main()
  File "/usr/bin/py3clean", line 196, in main
    pfiles = set(dpf.from_package(options.package))
  File "/usr/share/python3/debpython/files.py", line 53, in from_package
    raise Exception("cannot get content of %s" % package_name)
Exception: cannot get content of command-not-found
error running python rtupdate hook command-not-found
dpkg-query: package 'commix' is not installed
    main()
Exception: cannot get content of commix
error running python rtupdate hook commix
dpkg-query: package 'creddump7' is not installed
    main()
Exception: cannot get content of creddump7
error running python rtupdate hook creddump7
dpkg-query: package 'dnsrecon' is not installed
    main()
Exception: cannot get content of dnsrecon
error running python rtupdate hook dnsrecon
dpkg-query: package 'fern-wifi-cracker' is not installed
    main()
Exception: cannot get content of fern-wifi-cracker
error running python rtupdate hook fern-wifi-cracker
dpkg-query: package 'gobject-introspection' is not installed
    main()
Exception: cannot get content of gobject-introspection
error running python rtupdate hook gobject-introspection
dpkg-query: package 'john-data' is not installed
    main()
Exception: cannot get content of john-data
error running python rtupdate hook john-data
dpkg-query: package 'kali-undercover' is not installed
    main()
Exception: cannot get content of kali-undercover
error running python rtupdate hook kali-undercover
dpkg-query: package 'legion' is not installed
    main()
Exception: cannot get content of legion
error running python rtupdate hook legion
dpkg-query: package 'powershell-empire' is not installed
    main()
Exception: cannot get content of powershell-empire
error running python rtupdate hook powershell-empire
dpkg-query: package 'recon-ng' is not installed
    main()
Exception: cannot get content of recon-ng
error running python rtupdate hook recon-ng
dpkg-query: package 'responder' is not installed
    main()
Exception: cannot get content of responder
error running python rtupdate hook responder
dpkg-query: package 'set' is not installed
    main()
Exception: cannot get content of set
error running python rtupdate hook set
dpkg-query: package 'spiderfoot' is not installed
    main()
Exception: cannot get content of spiderfoot
error running python rtupdate hook spiderfoot
dpkg-query: package 'sqlmap' is not installed
    main()
Exception: cannot get content of sqlmap
error running python rtupdate hook sqlmap
dpkg-query: package 'unicorn-magic' is not installed
    main()
Exception: cannot get content of unicorn-magic
error running python rtupdate hook unicorn-magic
dpkg: error processing package python3 (--configure):
 installed python3 package post-installation script subprocess returned error exit status 4
dpkg: dependency problems prevent configuration of hashcat-data:
 hashcat-data depends on python3; however:
  Package python3 is not configured yet.
dpkg: error processing package hashcat-data (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of criu: criu depends on python3:any; however: Package python3 is not configured yet.
dpkg: error processing package criu (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of python3-protobuf: python3-protobuf depends on python3 (<< 3.12); however: Package python3 is not configured yet. python3-protobuf depends on python3 (>= 3.10~); however: Package python3 is not configured yet. python3-protobuf depends on python3:any; however: Package python3 is not configured yet.
dpkg: error processing package python3-protobuf (--configure): dependency problems - leaving unconfigured Errors were encountered while processing: python3 hashcat-data criu python3-protobuf needrestart is being skipped since dpkg has failed E: Sub-process /usr/bin/dpkg returned an error code (1)
I tried multiple solutions like "Dependency problems, leaving unconfigured" for many packages Dependency errors for python3 and many others when I run sudo apt-get upgrade but still nothing works and I get the same error
karel
  • 122,292
  • 133
  • 301
  • 332
