My bluetooth connections are very sporadic and I often get different error messages in blueman while trying to connect to paired devices. One of them is 'Connection Failed: Input/output error' and another is 'Connection failed: le-connection-about-by-local'. Sometimes my bluetooth mouse is connected but doesn't work and then disconnects. Also, occasionally, if my headphones are connected the sound stutters -- I don't know if that is part of this problem but it might be worth mentioning.
I have the same version of Ubuntu installed on an older laptop and there the bluetooth works fine. I'm hoping this is a software and not a hardware issue.
Here is the output of inxi -Fxz
System:
  Kernel: 5.15.0-57-lowlatency x86_64 bits: 64 compiler: gcc v: 11.3.0
    Desktop: MATE 1.26.0 Distro: Ubuntu 22.04.1 LTS (Jammy Jellyfish)
Machine:
  Type: Laptop System: LENOVO product: 82K2 v: IdeaPad Gaming 3 15ACH6
    serial: <superuser required>
  Mobo: LENOVO model: LNVNB161216 v: SDK0J40700 WIN
    serial: <superuser required> UEFI: LENOVO v: H3CN30WW(V2.00)
    date: 06/28/2021
Battery:
  ID-1: BAT1 charge: 37.2 Wh (80.2%) condition: 46.4/45.0 Wh (103.1%)
    volts: 12.1 min: 11.5 model: 0x53 0x4D 0x50 0x00 0x32 0x30 0x 0x4C 0x32
    0x30 0x4D 0x33 0x50 0x4500
    status: Discharging
CPU:
  Info: 6-core model: AMD Ryzen 5 5600H with Radeon Graphics bits: 64
    type: MT MCP arch: Zen 3 rev: 0 cache: L1: 384 KiB L2: 3 MiB L3: 16 MiB
  Speed (MHz): avg: 1458 high: 1899 min/max: 400/4280 boost: enabled cores:
    1: 1662 2: 1738 3: 1063 4: 1298 5: 1899 6: 1611 7: 1221 8: 1719 9: 977
    10: 1461 11: 1393 12: 1465 bogomips: 79049
  Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
Graphics:
  Device-1: NVIDIA GA107M [GeForce RTX 3050 Ti Mobile] vendor: Lenovo
    driver: nvidia v: 525.60.11 bus-ID: 01:00.0
  Device-2: AMD Cezanne vendor: Lenovo driver: amdgpu v: kernel
    bus-ID: 05:00.0
  Device-3: IMC Networks Integrated Camera type: USB driver: uvcvideo
    bus-ID: 1-3:3
  Display: x11 server: X.Org v: 1.21.1.3 driver: X:
    loaded: amdgpu,ati,nvidia unloaded: fbdev,modesetting,nouveau,vesa
    gpu: amdgpu resolution: 1920x1080~120Hz
  OpenGL: renderer: NVIDIA GeForce RTX 3050 Ti Laptop GPU/PCIe/SSE2
    v: 4.6.0 NVIDIA 525.60.11 direct render: Yes
Audio:
  Device-1: AMD Renoir Radeon High Definition Audio vendor: Lenovo
    driver: snd_hda_intel v: kernel bus-ID: 05:00.1
  Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
    vendor: Lenovo driver: N/A bus-ID: 05:00.5
  Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
    v: kernel bus-ID: 05:00.6
  Sound Server-1: ALSA v: k5.15.0-57-lowlatency running: yes
  Sound Server-2: JACK v: 1.9.20 running: no
  Sound Server-3: PulseAudio v: 15.99.1 running: no
  Sound Server-4: PipeWire v: 0.3.48 running: yes
Network:
  Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
    vendor: Lenovo driver: r8169 v: kernel port: 2000 bus-ID: 02:00.0
  IF: enp2s0 state: down mac: <filter>
  Device-2: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
    vendor: Lenovo driver: mt7921e v: kernel bus-ID: 03:00.0
  IF: wlo1 state: up mac: <filter>
Bluetooth:
  Device-1: Broadcom BCM20702A0 Bluetooth 4.0 type: USB driver: btusb v: 0.8
    bus-ID: 1-2:2
  Report: hciconfig ID: hci0 rfk-id: 2 state: up address: <filter>
    bt-v: 2.1 lmp-v: 4.0
  Device-2: Foxconn / Hon Hai Wireless_Device type: USB driver: btusb
    v: 0.8 bus-ID: 1-4:4
  Report: ID: hci1 rfk-id: 3 state: up address: <filter> bt-v: 3.0
    lmp-v: 5.2
Drives:
  Local Storage: total: 476.94 GiB used: 260.6 GiB (54.6%)
  ID-1: /dev/nvme0n1 vendor: Samsung model: MZALQ512HBLU-00BL2
    size: 476.94 GiB temp: 33.9 C
Partition:
  ID-1: / size: 321.04 GiB used: 260.21 GiB (81.1%) fs: ext4 dev: /dev/dm-0
    mapped: nvme0n1p6_crypt
  ID-2: /boot size: 1.88 GiB used: 363.4 MiB (18.8%) fs: ext4
    dev: /dev/nvme0n1p5
  ID-3: /boot/efi size: 256 MiB used: 37.5 MiB (14.7%) fs: vfat
    dev: /dev/nvme0n1p1
Swap:
  Alert: No swap data was found.
Sensors:
  System Temperatures: cpu: 46.0 C mobo: N/A
  Fan Speeds (RPM): N/A
  GPU: device: nvidia screen: :0.0 temp: 41 C device: amdgpu temp: 43.0 C
Info:
  Processes: 410 Uptime: 1m Memory: 5.65 GiB used: 2.13 GiB (37.8%)
  Init: systemd runlevel: 5 Compilers: gcc: 11.3.0 Packages: 3562 Shell: Bash
  v: 5.1.16 inxi: 3.3.13
and here is the output of sudo dmesg |grep -i bluetooth:
[   15.146287] Bluetooth: Core ver 2.22
[   15.146318] NET: Registered PF_BLUETOOTH protocol family
[   15.146320] Bluetooth: HCI device and connection manager initialized
[   15.146325] Bluetooth: HCI socket layer initialized
[   15.146328] Bluetooth: L2CAP socket layer initialized
[   15.146331] Bluetooth: SCO socket layer initialized
[   15.305589] Bluetooth: hci0: BCM: chip id 63
[   15.307588] Bluetooth: hci0: BCM: features 0x07
[   15.338576] Bluetooth: hci0: owen-IdeaPad-Gaming-3-15ACH6 #1
[   15.338580] Bluetooth: hci0: BCM20702A1 (001.002.014) build 0000
[   15.338663] Bluetooth: hci1: Device setup in 138095 usecs
[   15.341727] Bluetooth: hci0: BCM: firmware Patch file not found, tried:
[   15.341734] Bluetooth: hci0: BCM: 'brcm/BCM20702A1-0a5c-21e8.hcd'
[   15.341737] Bluetooth: hci0: BCM: 'brcm/BCM-0a5c-21e8.hcd'
[   15.477669] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   15.477674] Bluetooth: BNEP filters: protocol multicast
[   15.477680] Bluetooth: BNEP socket layer initialized
[   20.269474] Bluetooth: RFCOMM TTY layer initialized
[   20.269485] Bluetooth: RFCOMM socket layer initialized
[   20.269492] Bluetooth: RFCOMM ver 1.11
[   34.392228] Bluetooth: hci0: corrupted ACL packet
[   34.504588] Bluetooth: hci0: corrupted ACL packet
[   34.505068] Bluetooth: hci0: corrupted ACL packet
[   34.538469] Bluetooth: hci0: ACL packet for unknown connection handle 2816
[   34.549697] Bluetooth: hci0: corrupted ACL packet
Due to a mysterious problem with my external adapter, when I have this problem I have to unplug the adapter and plug it back in; this fixes the problem.
