I am running a live installation of Ubuntu 20.04 LTS with Persistent Storage of 40GB. For some reason I can not install anything without getting the error Unable to correct problems, you have held broken packages. (see full output below). For instance, I am trying to install Keepass2. I have added the repositories sudo apt-add-repository ppa:jtaylor/keepass, I have updated apt sudo apt-get update && sudo apt-get upgrade, and yet when I run sudo apt-get install keepass2 -y I still get that same error! I did almost exactly the same process when trying to install i2p, and I also got the broken packages error. I also can not open the Ubuntu Software app.
Full Output of sudo apt-get install keepass2 -y:
Reading package lists... Done
Building dependency tree
keepass2 : Depends: mono-runtime (>= 3.0~) but it is not installable
Depends: libmono-corlib4.5-cil (>= 5.18.0.240) but it is not installable
Depends: libmono-system-drawing4.0-cil (>= 5.12.0.309) but it is not installable
Depends: libmono-system-security4.0-cil (>= 5.18.0.240) but it is not installable
Depends: libmono-system-windows-forms4.0-cil (>= 5.16.0.220) but it is not installable
Depends: libmono-system-xml4.0-cil (>= 4.6.1.3) but it is not installable
Depends: libmono-system4.0-cil (>= 5.18.0.240) but it is not installable
Recommends: xsel but it is not installable
Full Output of sudo apt-get dist-upgrade:
[sudo] password for i2p:
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
PPAs Installed:
/etc/apt/sources.list:deb cdrom:[Ubuntu 20.04.5 LTS _Focal Fossa_ - Release amd64 (20220831)]/ focal main restricted
/etc/apt/sources.list:deb http://archive.ubuntu.com/ubuntu/ focal main restricted
/etc/apt/sources.list:deb http://security.ubuntu.com/ubuntu/ focal-security main restricted
/etc/apt/sources.list:deb http://archive.ubuntu.com/ubuntu/ focal-updates main restricted
/etc/apt/sources.list.d/i2p-maintainers-ubuntu-i2p-focal.list:deb http://ppa.launchpad.net/i2p-maintainers/i2p/ubuntu focal main
/etc/apt/sources.list.d/i2p-maintainers-ubuntu-i2p-focal.list:# deb-src http://ppa.launchpad.net/i2p-maintainers/i2p/ubuntu focal main
/etc/apt/sources.list.d/i2p-maintainers-ubuntu-i2p-focal.list.save:deb http://ppa.launchpad.net/i2p-maintainers/i2p/ubuntu focal main
/etc/apt/sources.list.d/i2p-maintainers-ubuntu-i2p-focal.list.save:# deb-src http://ppa.launchpad.net/i2p-maintainers/i2p/ubuntu focal main
/etc/apt/sources.list.d/jtaylor-ubuntu-keepass-focal.list:deb http://ppa.launchpad.net/jtaylor/keepass/ubuntu focal main
/etc/apt/sources.list.d/jtaylor-ubuntu-keepass-focal.list:# deb-src http://ppa.launchpad.net/jtaylor/keepass/ubuntu focal main
