How do I make my GPU compatible safely without getting it to freeze on boot with workarounds?
(base) wal@len:~$ lspci | grep VGA
0000:00:02.0 VGA compatible controller: Intel Corporation Device 9a78 (rev 01)
(base) wal@len:~$ sudo lshw -C video
[sudo] password for wal:
  *-display
       description: VGA compatible controller
       product: Intel Corporation
       vendor: Intel Corporation
       physical id: 2
       bus info: pci@0000:00:02.0
       logical name: /dev/fb0
       version: 01
       width: 64 bits
       clock: 33MHz
       capabilities: pciexpress msi pm vga_controller bus_master cap_list rom fb
       configuration: depth=32 driver=i915 latency=0 mode=1920x1080 resolution=1920,1080 visual=truecolor xres=1920 yres=1080
       resources: iomemory:600-5ff iomemory:400-3ff irq:158 memory:6002000000-6002ffffff memory:4000000000-400fffffff ioport:3000(size=64) memory:c0000-dffff memory:4010000000-4016ffffff memory:4020000000-40ffffffff
(base) wal@len:~$ lspci -nn |egrep "VGA|Display"
0000:00:02.0 VGA compatible controller [0300]: Intel Corporation Device [8086:9a78] (rev 01)
(base) wal@len:~$ sudo apt-get install xserver-xorg-video-intel
Reading package lists... Done
Building dependency tree... Done
xserver-xorg-video-intel is already the newest version (2:2.99.917+git20210115-1).
xserver-xorg-video-intel set to manually installed.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
edit(@matigo): I did upgrade my OS from 20 to 22 in the past, but looks like the kernel thing didn't apply?
(base) wal@len:~$ uname -r
5.15.0-56-generic
(base) wal@len:~$ sudo apt -f install [sudo] password for wal: Reading package lists... Done Building dependency tree... Done Reading state information... Done 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
(base) wal@len:~$ sudo aptitude -f install No packages will be installed, upgraded, or removed. 0 packages upgraded, 0 newly installed, 0 to remove and 0 not upgraded. Need to get 0 B of archives. After unpacking 0 B will be used.
(base) wal@len:~$ sudo apt install update-manager-core Reading package lists... Done Building dependency tree... Done Reading state information... Done update-manager-core is already the newest version (1:22.04.10). update-manager-core set to manually installed. 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
(base) wal@len:~$ sudo apt full-upgrade Reading package lists... Done Building dependency tree... Done Reading state information... Done Calculating upgrade... Done
News about significant security updates, features and services will
appear here to raise awareness and perhaps tease /r/Linux ;)
Use 'pro config set apt_news=false' to hide this and future APT news.
(base) wal@len:~$ sudo do-release-upgrade Checking for a new Ubuntu release There is no development version of an LTS available. To upgrade to the latest non-LTS development release set Prompt=normal in /etc/update-manager/release-upgrades.
(base) wal@len:~$ lsb_release -a No LSB modules are available. Distributor ID: Ubuntu Description: Ubuntu 22.04.1 LTS Release: 22.04 Codename: jammy
Kar19
  • 459
  • 28
Your Intel GPU is fully supported. There is nothing to worry about.
It is using the i915 driver. If everything works OK, then I see no problem.
Pilot6
  • 92,041
