I did a fresh install in the end
I recently installed ubuntu and was trying to change my drivers from xserver to nvidia when I was first hit with the message:
 apt : Depends: libapt-pkg6.0 (>= 2.4.9) but 2.4.8 is to be installed
 apt-utils : Depends: apt (= 2.4.8) but 2.4.9 is to be installed
I have tried reinstalling libapt 2.4.8 and could not find a .deb for 2.4.9 and the message still appears when using apt-get. For example;
sudo apt-get install libapt-pkg6.0
Reading package lists... Done
Building dependency tree... Done
libapt-pkg6.0 is already the newest version (2.4.8).
libapt-pkg6.0 set to manually installed.
You might want to run 'apt --fix-broken install' to correct these.
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
apt -fix--broken install and many other solutions for missing dependencies did not work either.
Any insight appreciated!
new to ubuntu running 22.04 server LTS with gnome
