-2
I have been an ubuntu user for years, and i am currently a Computer Science student, learning coding, networks & it. Do you recommend me to use the 22.04 LTS release, or the latest regular release?
My system is compatible with both releases, but I am not sure if it's better to have the LTS with added PPA's regarding dev tools, or go with the latest release resulting in less added ppa's. I care about new features but i want a reasonably stable system too at the level windows 10 is for an tech savvy user (I refer to that OS just for reference).
Maybe there is no difference for my usage scenario.
andrew.46
  • 39,359
In any case: if in doubt use an LTS version
LTS is the safe choice.
  • It has longer support time, meaning you are not pushed to upgrade too soon. A non LTS version currently has 9 months support, so you have to follow always the upcoming releases (upgrade in every ~6 months). Till the LTS has long years of support, you can even skip the next LTS if you will. Check out releases and support times here: https://wiki.ubuntu.com/Releases
  • Also if you later realize you want a newer version you can upgrade to it, the other way around (when you install something newer and you realize you want to go back to the latest LTS ) is not supported.
I would recommend to have an LTS on your main notebook/desktop and you can have any time a virtual machine if you want to try a newer version or missing something from the LTS.
redseven
  • 842
  • 14
