I have an Ubuntu virtual machine which I access via SSH. When I execute the who command I get nothing. Moreover I get this output when executing systemctl --user:
Failed to connect to bus: No such file or directory
When executing systemctl status dbus I get everything normal except for this line:
[system] Failed to activate service 'org.freedesktop.login1': timed out (service_start_timeout=25000ms)
The output before log is:
dbus.service - D-Bus System Message Bus
Loaded: loaded (/lib/systemd/system/dbus.service; static; vendor preset: enabled)
Active: active (running) since Tue 2023-01-03 14:12:08 UTC; 20h ago
Docs: man:dbus-daemon(1)
Main PID: 1368 (dbus-daemon)
Tasks: 1 (limit: 4915)
CGroup: /system.slice/dbus.service
└─1368 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
The output of systemctl status systemd-logind is:
systemd-logind.service - Login Service
Loaded: loaded (/lib/systemd/system/systemd-logind.service;
Active: failed (Result: exit-code) since Wed 2023-01-04 11:25:15 UTC; 1h 44min ago
Docs: man:systemd-logind.service(8)
man:logind.conf(5)
https://www.freedesktop.org/wiki/Software/systemd/logind
https://www.freedesktop.org/wiki/Software/systemd/multiseat
Process: 24112 ExecStart=/lib/systemd/systemd-logind (code=exited, status=1/FAILURE)
Main PID: 24112 (code=exited, status=1/FAILURE)
Status: "Shutting down..."
Any suggestion about what is going on?
