I installed Firefox as a snap and it set my partition's mount point to , /var/snap/firefox/common/host-hunspell. Now, I'm trying to remove the snap installation of Firefox, and it will not completely allow me, failing at this step:
Remove data for snap "firefox" (2211) (unlinkat /var/snap/firefox/common/host-hunspell/nl_BE.dic: read-only file system)
How can I fully remove Firefox and safely clear this mount point without damaging anything?
The only thing that worked for me was to use umount:
umount /var/snap/firefox/common/host-hunspell
Then I was able to remove firefox and snapd
Got it from here
lepe
  • 1,506
lsblk: root partition mounted on / and /var/snap/firefox/common/host-hunspell?
try:
snap disconnect firefox:host-hunspell
I found that, even after unmounting:
And removing snap and the snap version of firefox:
sudo apt remove --purge snapd firefox
Upon reboot, /var/snap/firefox/common/host-hunspell was back.
Following this guide helped me resolve the snap mount tomfoolery: Uninstalling Snap and Resolving Persistent Mount Points on Ubuntu 22.04
After you umount, you need to also remove:
rm /etc/systemd/system/var-snap-firefox-common-host\\x2dhunspell.mount
No more snap mount on reboot
Alnitak
  • 331
