Im on ubuntu 22.04 and i tried installing wine. i followed all the steps on the website and it was good the repository was working but when i did sudo apt install --install-recommends winehq-stable it gave me an error:
The following packages have unmet dependencies: winehq-stable : Depends: wine-stable (= 7.0.1~jammy-1) E: Unable to correct problems, you have held broken packages.
Please help
I have no problems to install it.
sudo dpkg --add-architecture i386
add 32-bit arch. Now we need the key for repo
wget -O- https://dl.winehq.org/wine-builds/winehq.key | sudo gpg --dearmor | sudo tee /usr/share/keyrings/winehq.gpg
Then we add the repo for jammy.
echo deb [signed-by=/usr/share/keyrings/winehq.gpg] http://dl.winehq.org/wine-builds/ubuntu/ $(lsb_release -cs) main | sudo tee /etc/apt/sources.list.d/winehq.list
Now
sudo apt update && sudo apt install --install-recommends winehq-stable
Gives on my System
wine --version
wine-7.0.1
Sidenote I have only mozillateam repo enabled (for firefox and thunderbird packages). All other packages on my system from default repos.
source
nobody
  • 5,792
