I am trying to run Quartus 13 on Ubuntu 22.04 (64-bit) and like many other people the libpng12.so.0 is not allowing it to run. First it could not find the file. Then I downloaded and installed the package from an answer to another question, then placed the file manually in the Quartus installation folder so the error changed to:
quartus: error while loading shared libraries: libpng12.so.0: wrong ELF class: ELFCLASS64
The installation folder of Quartus has the path: /home/developer/n/quartus/bin
Now I asked this question because many of the solutions worked fine till Ubuntu 21. I need a fix for Ubuntu 22.04 for a 32-bit libpng12 package (I presume this is why the ELF class error occurs).
The command find -name libpng12 returns:
./usr/local/lib/libpng12.so.0
./usr/lib/x86_64-linux-gnu/libpng12.so.0
./home/developer/n/libpng/.libs/libpng12.so.0
./root/libpng-1.2.54/.libs/libpng12.so.0
find: ‘./run/user/1000/doc’: Permission denied
find: ‘./run/user/1000/gvfs’: Permission denied
./snap/core/14399/lib/x86_64-linux-gnu/libpng12.so.0
./snap/core/14399/usr/lib/x86_64-linux-gnu/libpng12.so.0
I copied all of them one by one to /quartus/bin and every time I got the same ELFCLASS error.
I also tried putting the path of libpng12 in ld.so.conf file in /etc then ran ldconfig but still the same problem. I have tried these answers:
Install libpng12 on ubuntu 22.04
https://bbs.archlinux.org/viewtopic.php?id=212077
https://community.intel.com/t5/Programmable-Devices/Quartus-can-t-find-shared-library/td-p/161251
This no longer works:
sudo apt-get install libpng12-0:i386
This package isnt available any more: https://packages.ubuntu.com/xenial/i386/libpng12-0/download
How do I get my software to run?
