I've gotten a new laptop and upgraded to 22.04, but I can no longer seem to get the l2tp/ip-sec VPN required for my job working anymore. I'm using the Gnome NetworkManager to configure this (just like the old system) and I do successfully "connect" and receive an IP address, but I can't seem to ping anything on the destination network.
I still have my old install, so I connected to the VPN on both laptops and pasted the output of "ip a" and "ip route show" below just to compare. I do see one difference in the "ip a" command (shown below), but I'm not sure what I need to do to get them to match or if it's even the problem...
Old
13: ppp0: <POINTOPOINT,MULTICAST,NOARP,UP,LOWER_UP> mtu 1400 qdisc fq_codel state UNKNOWN group default qlen 3
link/ppp
inet 192.168.50.6/32 scope global noprefixroute ppp0
   valid_lft forever preferred_lft forever
New
7: ppp0: <POINTOPOINT,MULTICAST,NOARP,UP,LOWER_UP> mtu 1400 qdisc fq_codel state UNKNOWN group default qlen 3
    link/ppp
    inet 192.168.50.3 peer 216.83.74.140/32 scope global ppp0
    inet 192.168.50.3/32 scope global noprefixroute ppp0
Old
default via 192.168.86.1 dev wlp0s20f3 proto dhcp metric 600
169.254.0.0/16 dev virbr0 scope link metric 1000 linkdown
172.17.0.0/16 dev docker0 proto kernel scope link src 172.17.0.1 linkdown
172.18.0.0/16 dev br-c395aa5e5b48 proto kernel scope link src 172.18.0.1
192.168.1.0/24 via 192.168.50.1 dev ppp0 proto static metric 50
192.168.10.0/24 via 192.168.50.1 dev ppp0 proto static metric 50
192.168.13.0/24 via 192.168.50.1 dev ppp0 proto static metric 50
192.168.50.1 dev ppp0 proto static scope link metric 50
192.168.86.0/24 dev wlp0s20f3 proto kernel scope link src 192.168.86.43 metric 600
192.168.86.1 dev wlp0s20f3 proto static scope link metric 600
192.168.122.0/24 dev virbr0 proto kernel scope link src 192.168.122.1 linkdown
216.83.74.140 via 192.168.86.1 dev wlp0s20f3 proto static metric 600
New
192.168.86.1 dev wlp0s20f3 proto static scope link metric 50
216.83.74.140 dev ppp0 proto kernel scope link src 192.168.50.3
216.83.74.140 via 192.168.86.1 dev wlp0s20f3 proto static metric 50
cmwarre
  • 13
It's a routing bug since NetworkManager 1.36. Try deleting the spurious route that has no metric with :
sudo ip addr del 192.168.50.3 peer 216.83.74.140 dev ppp0
The upstream NetworkManager bug report is :
Related NetworkManager-l2tp bug report:
