I have a script that sends me some info about different machines, and it's working fine in Fedora machines, but Ubuntu 20.04 gives me error for only one printf. I can't seem to see what am I doing wrong. So the statement is:
#printf "Last logins (last -10) \n `last -10` \n"
bash: printf: ` ': invalid format character
 vecn1    pts/8        tmux(1233684).
whereas similar statements works fine:
printf "Default gw (ip ro ls) \n`ip ro ls` \n"
default via 192.168.111.1 dev en0 proto dhcp src 192.168.111.6 metric 100
192.168.111.0/24 dev en0 proto kernel scope link src 192.168.111.6
192.168.111.1 dev en0 proto dhcp scope link src 192.168.111.6 metric 100
What am I doing wrong? Maybe those "%" numbers? Not sure why are there. Normally is just a hostname (ip). If I do just last -10 following is the output
vecn1    pts/8        tmux(1233684).%3 Mon Dec 26 11:29 - 12:01  (00:31)
vecn1    pts/7        tmux(1233684).%2 Mon Dec 26 11:29 - 12:01  (00:31)
vecn1    pts/6        tmux(1233684).%1 Mon Dec 26 11:29 - 12:01  (00:31)
vecn1    pts/5        tmux(1233684).%0 Mon Dec 26 11:29 - 11:29  (00:00)
vecn1    pts/8        tmux(1232989).%3 Mon Dec 26 11:27 - 11:29  (00:01)
vecn1    pts/7        tmux(1232989).%2 Mon Dec 26 11:27 - 11:29  (00:01)
vecn1    pts/6        tmux(1232989).%1 Mon Dec 26 11:27 - 11:29  (00:01)
vecn1    pts/5        tmux(1232989).%0 Mon Dec 26 11:27 - 11:27  (00:00)
vecn1    pts/8        tmux(1198190).%3 Mon Dec 26 11:03 - 11:04  (00:00)
vecn1    pts/7        tmux(1198190).%2 Mon Dec 26 11:03 - 11:04  (00:00)
wtmp begins Wed Jun 22 17:27:34 2022
Thanks
muru
  • 207,228
DenisZ
  • 223
Yes it's likely the % symbols.
You should always avoid injecting code into the format string of the printf function; instead pass the result of the command as a argument using the appropriate format specifier (%s in the case of a string):
printf 'Last logins (last -10)\n%s\n' "`last -10`"
or better (avoiding the deprecated backtick form of command substitution)
printf 'Last logins (last -10)\n%s\n' "$(last -10)"
steeldriver
  • 142,475
