I've decided to make the plunge into Kubuntu in lieu of "upgrading" to Windows 10/11 with very little experience with Linux, and I've run into trouble quite early.
In short, I want to use this as my main PC from which I stream Steam games, among other things.
Everything was going swimmingly with my install until it came time to make a new Steam Library folder on my secondary NVMe drive. I tried creating a folder with Steam and it gave me an error that the drive was read-only.
I thought surely Steam must be bugged, so I went to make the folder myself via the Kubuntu GUI. Nope, read only. Mind you this is on a fresh install, brand new drive I just mounted as ext4 for maximum compatibility with Steam. Steam will let me install stuff on my primary drive just fine, but neither it nor I can create a new folder via GUI on nvme0n1.
I've done unmounting, remounting, via command line terminal and GUI (via KDE Partition Manager), and I'm becoming very frustrated. Here's the results from some commands I found were commonly asked about in similar questions:
username@username-System-Product-Name:~$ sudo parted -l
Model: Linux device-mapper (linear) (dm)
Disk /dev/mapper/vgkubuntu-swap_1: 2051MB
Sector size (logical/physical): 512B/512B
Partition Table: loop
Disk Flags:
Number Start End Size File system Flags 1 0.00B 2051MB 2051MB linux-swap(v1)
Model: Linux device-mapper (linear) (dm) Disk /dev/mapper/vgkubuntu-root: 998GB Sector size (logical/physical): 512B/512B Partition Table: loop Disk Flags:
Number Start End Size File system Flags 1 0.00B 998GB 998GB ext4
Model: CT1000P3SSD8 (nvme) Disk /dev/nvme0n1: 1000GB Sector size (logical/physical): 512B/512B Partition Table: gpt Disk Flags:
Number Start End Size File system Name Flags 1 1049kB 538MB 537MB fat32 boot, esp 2 538MB 1000GB 1000GB lvm
Model: INTEL SSDPEKNW010T8 (nvme) Disk /dev/nvme1n1: 1024GB Sector size (logical/physical): 512B/512B Partition Table: gpt Disk Flags:
username@username-System-Product-Name:~$ sudo fsck /dev/nvme1n1 fsck from util-linux 2.37.2 e2fsck 1.46.5 (30-Dec-2021) ext2fs_open2: Bad magic number in super-block fsck.ext2: Superblock invalid, trying backup blocks... fsck.ext2: Bad magic number in super-block while trying to open /dev/nvme1n1
The superblock could not be read or does not describe a valid ext2/ext3/ext4 filesystem. If the device is valid and it really contains an ext2/ext3/ext4 filesystem (and not swap or ufs or something else), then the superblock is corrupt, and you might try running e2fsck with an alternate superblock: e2fsck -b 8193 <device> or e2fsck -b 32768 <device>
Found a gpt partition table in /dev/nvme1n1
username@username-System-Product-Name:~$ sudo fdisk -l Disk /dev/loop0: 61.96 MiB, 64970752 bytes, 126896 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop1: 4 KiB, 4096 bytes, 8 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop2: 63.23 MiB, 66301952 bytes, 129496 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop3: 163.29 MiB, 171225088 bytes, 334424 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop4: 238.43 MiB, 250015744 bytes, 488312 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop5: 400.8 MiB, 420265984 bytes, 820832 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop6: 346.33 MiB, 363151360 bytes, 709280 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop7: 91.69 MiB, 96141312 bytes, 187776 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/nvme1n1: 953.87 GiB, 1024209543168 bytes, 2000409264 sectors Disk model: INTEL SSDPEKNW010T8
Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: gpt Disk identifier: D4E53ED1-F214-2B48-967F-0432400645C1
Disk /dev/nvme0n1: 931.51 GiB, 1000204886016 bytes, 1953525168 sectors Disk model: CT1000P3SSD8
Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: gpt Disk identifier: 0A634D48-6E20-4CF5-B5B6-C1F09A298087
Device Start End Sectors Size Type /dev/nvme0n1p1 2048 1050623 1048576 512M EFI System /dev/nvme0n1p2 1050624 1953523711 1952473088 931G Linux LVM
Disk /dev/mapper/vgkubuntu-root: 929.1 GiB, 997611012096 bytes, 1948459008 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/mapper/vgkubuntu-swap_1: 1.91 GiB, 2051014656 bytes, 4005888 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop8: 49.62 MiB, 52031488 bytes, 101624 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
For the record, I have no idea what those tons of /dev/loop#s are, but from a cursory web search it doesn't seem like they're likely to be the culprit.
I also don't understand why Linux/Kubuntu apparently mounted a third, virtual drive in the form of /dev/mapper/vgkubuntu-root, but I'm sure it's perfectly logical to someone who has any idea what they're doing, unlike myself. I made the plunge into Linux without so much as learning the difference between /dev/ and /root/ and such, which believe me I plan to learn in the next few hours/days.
For now... if you would kindly help me just get a big ol' game installed on /nvme1n1, I'd very much appreciate it.
Edit on 12/23/22 @ 1231 ET : Steps taken since reading the first two comments:
Create a new partition table (type: gpt) on ‘/dev/nvme1n1’
Job: Create new partition table on device ‘/dev/nvme1n1’
Command: sfdisk --wipe=always /dev/nvme1n1
Create new partition table on device ‘/dev/nvme1n1’: Success
Create a new partition table (type: gpt) on ‘/dev/nvme1n1’: Success
Create a new partition (488.28 GiB, ext4) on ‘/dev/nvme1n1’ Job: Create new partition on device ‘/dev/nvme1n1’ Command: sfdisk --force --append /dev/nvme1n1
Command: sfdisk --list --output Device,UUID /dev/nvme1n1 Create new partition ‘/dev/nvme1n1p1’: Success
Job: Create file system ‘ext4’ on partition ‘/dev/nvme1n1p1’ Command: mkfs.ext4 -qF /dev/nvme1n1p1
Command: sfdisk --part-type /dev/nvme1n1 1 0FC63DAF-8483-4772-8E79-3D69D8477DE4 Create file system ‘ext4’ on partition ‘/dev/nvme1n1p1’: Success
Job: Set the file system label on partition ‘/dev/nvme1n1p1’ to "SteamLibrary" Command: e2label /dev/nvme1n1p1 SteamLibrary Set the file system label on partition ‘/dev/nvme1n1p1’ to "SteamLibrary": Success
Job: Check file system on partition ‘/dev/nvme1n1p1’ Command: e2fsck -f -y -v /dev/nvme1n1p1 Check file system on partition ‘/dev/nvme1n1p1’: Success Create a new partition (488.28 GiB, ext4) on ‘/dev/nvme1n1’: Success
Still can't create a new folder in that partition. The option is greyed out if I right-click to "create new," and when I went into Properties->Permissions->Advanced Permissions for the new partition, it has a table like so:
| Type | Name | r | w | x | Effective |
| Owner | | X | X | X | rwx |
| Owning Group | | X | | X | r-x|
| Others | | X | | X | r-x |
I had the same experience. After reading your post, I changed the partition from ext4 to fat32 and had no issue after that.
Then I made another partition using exFat - also no permission issues. Using exFat is probably even better than Fat32 because exFat does not have the file size limitations that Fat32 does.
I had to run sudo apt install exfatprogs before being able to create an exFat partition. (Ubuntu 22.04)
hoatzin
  • 647
