Is there an equivalent snap command that does for Snaps what apt-get autoremove / apt-get autopurge does for Apt packages? (Also available as apt autoremove...)
Update 3: For the curious and those who end up here from Google, the equivalent command for FlatPak is flatpak uninstall --unused.
Update: I wanted to clarify the question after receiving an answer which states:
Snaps do not have dependencies like apt, so an equivalent to autoremove seems unnecessary.
This is incorrect. Consider the following (just one example of many):
$ snap list
Name               Version          Rev    Tracking         Publisher      Notes
bare               1.0              5      latest/stable    canonical✓     base
core               16-2.57.6        14399  latest/stable    canonical✓     core
core18             20221212         2667   latest/stable    canonical✓     base
core20             20221123         1738   latest/stable    canonical✓     base
$ sudo snap install nvim --classic
nvim v0.8.1 from neovim-snap (neovim-snap) installed
$ snap list
core22             20221129         444    latest/stable    canonical✓     base
nvim               v0.8.1           2775   latest/stable    neovim-snap    classic
$ sudo snap remove nvim
nvim removed
$ snap list
Before installing nvim, core22 was not installed. After removing it, core22 is left behind even though nothing depends on it now.
Update 2: In the above example, the installed dependency core22 is a base snap. Here's another example which demonstrates that the same issue is also present for non-base dependencies:
$ sudo snap list
$ sudo snap install falkon
falkon 22.08.2 from KDE✓ installed
$ snap list
falkon                                22.08.2          86     latest/stable    kde✓           -
kde-frameworks-5-98-qt-5-15-6-core20  5.98.0           9      latest/stable    kde✓           -
$ sudo snap remove falkon
falkon removed
$ snap list
After installing and then removing the falkon snap, the unused dependency kde-frameworks-5-... is left behind.
P Varga
  • 512
Snap AutoCleanUp
A often discussed question ... with a bunch of half-answers.
Since snap has no package systems that just upgrades in place , snap pulls dependencies with the packages and also keeps a copy of the last n versions of snaps
( and you are right if you think that snap uses your local storage like a mirrored registry with the last n versions )
Current State of Snap Auto-Cleaning:
In fact there is a Feature proposal since 2020 ( ~3 Years ) , so maybe spread some votes there ..
Snap Clean-Up / Auto-Purge Ways:
The behaviour closest to "auto-pruning" you can get:
  • Engage the auto-clean script to get rid of old versions ( found here )
  • disable auto-snapshots , their manual says it all:
    sudo snap set system snapshots.automatic.retention=no will disable it
    Automatic snapshot retention time is configured with the snapshots.automatic.retention system option. The default value is 31 days, and the value needs to be greater than 24 hours
    Disabling automatic snapshots will not affect preexisting, automatically generated snapshots, but only those generated by subsequent snap removals.
  • clean up the snapshots, there is a very good example script
There is no "exact-same" apt(-get) way of saving more space with snap , but amongst the top-tips there are:
  • Lower the "old versions" snapd keeps: sudo snap set system refresh.retain=2
    The refresh.retain value can be a number between 2 and 20. The default is refresh.retain=3 on Ubuntu Core systems and refresh.retain=2 on classic Ubuntu systems, such as those running Ubuntu 18.04 LTS (Bionic Beaver) and Ubuntu 16.04 LTS (Xenial Xerus).
  • clear the cache: sudo find /var/lib/snapd/cache/ -exec rm -v {} \; # Remove cache
The "Dangerous" non-moving part: locking against updates with refresh --hold
Preamble: You might run into outdated software and resulting security issues , so please be careful and update regularly by reinstalling or unholding the lock.
Another question also included:
even limiting unattended installation to Canonical-supported software
well
There was currently no way found to do this, except "pinning"( snap term "refresh hold")
How-To: snapd pinning
  • since 2.58+, there is refresh lock holding ( apt pinning equivalent )
  • it might be issued for one or all packages , with and without timelimit
  • snap refresh --hold "should" lock all updates
  • a specific example is sudo snap refresh --hold=24h firefox
How-To: update snapd "pinned" software
  • Variant A to update (firefox example), either sudo snap remove --purge firefox;sudo snap install firefox;sudo snap refresh --hold
  • Variant B to update sudo snap refresh --unhold firefox;sudo snap refresh firefox;sudo snap refresh --hold
After looking for a while, it is clear that there is no equivalent command currently.
P Varga
  • 512
