On open nvidia settings get next errors:
$ sudo nvidia-smi
ERROR: Unable to load info from any available system
(nvidia-settings:7395): GLib-GObject-CRITICAL **: 19:20:22.799: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
** Message: 19:20:22.801: PRIME: Requires offloading
** Message: 19:20:22.801: PRIME: is it supported? yes
** Message: 19:20:22.837: PRIME: Usage: /usr/bin/prime-select nvidia|intel|on-demand|query
** Message: 19:20:22.837: PRIME: on-demand mode: "1"
** Message: 19:20:22.837: PRIME: is "on-demand" mode supported? yes
In opened popup selected "NVIDIA On-Demand" option
Below some system information
$ uname -a
Linux legion 5.4.0-135-generic #152-Ubuntu SMP Wed Nov 23 20:19:22 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
$ lsb_release -a No LSB modules are available. Distributor ID: Ubuntu Description: Ubuntu 20.04.5 LTS Release: 20.04 Codename: focal
$ echo $XDG_SESSION_TYPE x11
$ mokutil --sb-state EFI variables are not supported on this system
$ test -d /sys/firmware/efi && echo efi || echo "Legacy(bios)" Legacy(bios)
$ dkms status nvidia, 515.86.01, 5.4.0-135-generic, x86_64: installed
$ lsmod | grep nvidia nvidia_uvm 1163264 0 nvidia_drm 61440 0 nvidia_modeset 1146880 1 nvidia_drm nvidia 40820736 11 nvidia_uvm,nvidia_modeset drm_kms_helper 184320 2 nvidia_drm,i915 drm 495616 15 drm_kms_helper,nvidia,nvidia_drm,i915
$ sudo lshw -c video -display
description: VGA compatible controller product: GP106M [GeForce GTX 1060 Mobile] vendor: NVIDIA Corporation physical id: 0 bus info: pci@0000:01:00.0 version: a1 width: 64 bits clock: 33MHz capabilities: pm msi pciexpress vga_controller bus_master cap_list rom configuration: driver=nvidia latency=0 resources: irq:138 memory:a3000000-a3ffffff memory:90000000-9fffffff memory:a0000000-a1ffffff ioport:4000(size=128) memory:a4080000-a40fffff
-display description: VGA compatible controller product: HD Graphics 630 vendor: Intel Corporation physical id: 2 bus info: pci@0000:00:02.0 version: 04 width: 64 bits clock: 33MHz capabilities: pciexpress msi pm vga_controller bus_master cap_list rom configuration: driver=i915 latency=0 resources: irq:135 memory:a2000000-a2ffffff memory:b0000000-bfffffff ioport:5000(size=64) memory:c0000-dffff
$ lspci -k | grep -A 2 -E "(VGA|3D)" 00:02.0 VGA compatible controller: Intel Corporation HD Graphics 630 (rev 04) Subsystem: Lenovo HD Graphics 630 Kernel driver in use: i915 -- 01:00.0 VGA compatible controller: NVIDIA Corporation GP106M [GeForce GTX 1060 Mobile] (rev a1) Subsystem: Lenovo GeForce GTX 1060 Max-Q 3GB Kernel driver in use: nvidia
$ nvidia-smi Mon Dec 19 19:23:22 2022
+-----------------------------------------------------------------------------+ | NVIDIA-SMI 515.86.01 Driver Version: 515.86.01 CUDA Version: 11.7 | |-------------------------------+----------------------+----------------------+ | GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC | | Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. | | | | MIG M. | |===============================+======================+======================| | 0 NVIDIA GeForce ... Off | 00000000:01:00.0 Off | N/A | | N/A 42C P8 4W / N/A | 2MiB / 3072MiB | 0% Default | | | | N/A | +-------------------------------+----------------------+----------------------+
+-----------------------------------------------------------------------------+ | Processes: | | GPU GI CI PID Type Process name GPU Memory | | ID ID Usage | |=============================================================================| | No running processes found | +-----------------------------------------------------------------------------+
Try reinstall to nvidia-driver-460 - did not help.
The another symptom - VLC stopped working too (open via terminal and try to play mkv/mp4)
$ vlc
VLC media player 3.0.9.2 Vetinari (revision 3.0.9.2-0-gd4c1aefe4d)
[00005591dce9a670] main libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
[00005591dcf38080] main playlist: playlist is empty
[00005591dcf6ef00] main audio output error: too low audio sample frequency (0)
[00007f8954d05160] main decoder error: failed to create audio output
[00005591dcf6ef00] vlcpulse audio output error: digital pass-through stream connection failure: Not supported
[00005591dcf6ef00] main audio output error: module not functional
libva info: VA-API version 1.7.0
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/iHD_drv_video.so
libva info: Found init function __vaDriverInit_1_7
libva info: va_openDriver() returns 0
Killed
But Parole media Player works fine, ffmpeg works too
  1. Assuming you're NOT using something downloaded from the nvidia webpage (remove anything such by running the installer with an appended <space>--uninstall)
  2. Hit the Win-key, start typing software and a pinkish icon will appear; click on it.
  3. Look up Additional drivers (a tab at top) and click on it.
  4. There should be a set of nvidia driver versions available. Set a tick to the left of one that is NOT selected.
  5. Wait for it to complete, then reboot and see if things work better.
Now note(1): I ASSUME that changing the driver DOES PURGE what there is before. If that isn't so; then you need to do it manually.
That can be done by $ sudo apt purge PACKAGENAME until you have all removed.
PACKAGENAME is at least one item in the second column of
dpkg --list | grep -E '^ii.*nvidia.*'
... i.e. nvidia packages that remains installed.
Note(2): $ nvidia-smi does not need sudo, normally(?)
Hannu
  • 6,605
  • 28
  • 45
