I created a USB stick from the ISO file of Xubuntu 22.10 but when I try to boot to it all I get is a mostly blank screen with the word GRUB and a flashing cursor at the upper left corner. I’ve created USB sticks before and have been using Ubuntu for many years so am not a newbie but have not seen this issue before. How can I get around it in order to do a fresh install?
Additionally, if I try typing anything at the cursor, after a few keystrokes, a single loud beep comes from the speakers with any further key presses.
The PC is a Gateway laptop with an AMD Turion64 processor and ATI Radeon Xpress 200M graphic display and is currently running Ubuntu Studio 22.10.
As an update, maybe I just found a workaround to the booting issue but problem not solved. Rather than using F10 and selecting the USB as the boot device, I used F2 and went to the BIOS Boot settings and changed the primary boot device to USB. That seemed to at least get it passed the GRUB prompt. For anyone reading this, the F2 and F10 key presses will likely be different on your own PCs.
That said, the USB stick’s indicator LED flashed for what seemed a long time while the screen remained blank other than the flashing cursor at the upper left but then suddenly filled with errors, the jist of which is:
Kernel panic - not syncing: No working init found.
DonP
  • 492
